Question about Acer Aspire 5315 Notebook
WLAN problems hi, i was using my laptop fine wirelessly til 5am then when i got up this morning it wont let me connect with the wlan. when i press the wlan button it says no wireless device. it was working perfect til this morning so i know the wireless is in there somewhere. thanks
  • towanda_mccl Sep 06, 2008
    I have the exact problem with same model of acer. Wireless connection just vanished......HELP
  • Anonymous Sep 07, 2008
    Me too! What a frustrating nightmare.
Try to uninstall and install again ' sorry my english not so good.
Posted on Aug 26, 2008
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
How do i turn on my wireless on msi u130?
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
May 14, 2011 | MSI Wind U100-030US Laptop
The WLAN light is off on my D-Link router. I can connect to the internet using an ethernet cable, but as soon as I unplug this, my connection terminates. I have tried resetting the router - done a system...
Hello there sir, FixYa pro member is on your service!
Well it looks like your wlan output has been blocked somehow, I want you to take your D-Link wireless router behind, notice little restart button on it, press it and hold it for 10 secconds in that position, after that use your router will be on factory settings, then WLAN ports should be automatically opened. If not just check wlan status enabled . Thanks for asking fixya.com sir have a nice day! :)
Please rate my solution if you have a moment or so, thanks in advance.
Apr 22, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant get my wireless connection to work not sure
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
Wireless light is off.
I am now on the same kind of computer and I used to have this problem- dell said it's a motherboard problem and they replaced it for free. Now it works just fine!
Jun 14, 2009 | Dell Vostro 1510 Laptop
WLAN WONT CONNET
Hi, Hope this will help u..
1>connect LAN and check the WLAN light on wireless router It should be ON and solid, If not the you might need to reset the router
2>On your laptop click on start go to run (in case of XP) or go to start then search box (in case of vista)
3>type services.msc
4>For Xp check the wireless zero configuration service should be automatic and running
5>For vista WLAN service should be automatic and running
6>then go to start > run ( FOr XP) or start >
>search box(in case for vista)
7>type ncpa.cpl >click on OK
8>right click on wireless network icon and click on view available wireless networks.
9> Choose your network and click connect,
10> If it asks for WEP key , It might be written in your router.
If this doesn't work, you can contact your Internet service provider.
Dec 27, 2008 | Computers & Internet
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Wireless Adapter Not Working
try uninstalling driver in device manager then reboot computer it will find it and will auto reinstall
Nov 16, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Acer Aspire 5315 Notebook Logo
156 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
