Question about Olympus EVOLT E-300 Digital Camera
Detection range of metering
How wide is the detection range of metering?
    Master:
  • 852 Answers
In Digital ESP metering and Center Weighted Averaging metering, the detection range is EV2 through EV20. In Spot metering it is EV3 through EV17 (50mm F2, equivalent to ISO100).
Posted on Sep 04, 2005
SOURCE:
My shade cloth is 3 metre wide i need 300 square metres.
square measurement is length X width
so it is 3 meters wide and you want 300 square meters that will be 100 meters X the 3 meters wide = 300 sq meters and that will around a full roll
Oct 26, 2017 | Office Equipment & Supplies
Have a 2001 pontiac aztec i change fuel pump but still giving problems put in the computer give me p0102 and p1189 replaced them still the same whats next
P0102 - The mass air flow (MAF) sensor is an air flow meter that measures the amount of air entering the engine. The powertrain control module (PCM) uses the MAF sensor signal in order to provide the correct fuel delivery for a wide range of engine speeds and loads. A small quantity of air entering the engine indicates deceleration or idle. A large quantity of air entering the engine indicates an acceleration or high load situation. The MAF sensor has an ignition 1 voltage circuit, a ground circuit, and a signal circuit. The PCM applies a voltage to the sensor on the signal circuit. The sensor uses the voltage in order to produce a frequency based on inlet air flow through the sensor bore. The frequency will vary within a range of around 2,000 Hertz at idle to about 10,000 Hertz at maximum engine load. DTC P0102 will set if the PCM detects a frequency signal lower than the possible range of a normally operating MAF sensor.
Sounds like you need a mass air flow sensor , but take it to a ASE certified repair shop an have it check , instead of just replacing it.
DTC P1189
The engine oil pressure switch is a normally closed switch that opens with the proper oil pressure. With the ignition switch turned ON and the engine not running, the PCM should detect a low signal voltage input. With the engine running, the pressure switch opens, and the PCM should detect a high signal voltage input. The PCM tests the state of the engine oil pressure circuit with the ignition switch turned ON, and the engine turned OFF. If the PCM detects a high voltage input on the engine oil pressure signal circuit, DTC P1189 will set.
Sounds
Oct 08, 2015 | Pontiac Cars & Trucks
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
Are vibration meters expencive?
There is a wide range in price from a few 100 dollars to the 1,000 of dollars for a vibration meter.
Jan 09, 2014 | Measuring Tools & Sensors
Epson B-310n inkjet Printer Shows Printer error Code 0xF4
Free Download 0x000000F4 Repair Program.0x000000F4 solution
Currently, this is my favorite tool because it fixed 0x000000F4 and 100% of other errors I had.
It automatically repairs a wide range of computer problems, such as 0x000000F4 and other blue screen errors, freezes, system file and registry damage, .dll and .sys errors, slow-downs, malware and other troubles.
The second reason why I recommend this one rather than any other tool is that this is the only program that not just detects and removes a virus or other malware, but also repairs the damage already done by a virus .
This is the only tool I know which is widely used even by PC technicians to remove Windows errors in automatic mode.
Let the program scan your computer and repair the errors it detects.
for more hrlp visit https://cbrtechsolutions.net
Apr 03, 2013 | Epson Business Inkjet B310N Network Color...
How to test electric water heater thermostats
1) Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-thermostats.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) There is no reliable way to test electric water heater thermostats.
This is because testing requires rotating the temperature selector, which may cause stuck-thermostat to temporarily unstick. So thermostat appears to work normally.
Moreover, thermostat come out of calibration over time, and the temperature selector might be on 125 but tank temperature at 100, and there is no specific way to measure calibration.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) I think it easier to replace both upper and lower thermostats to eliminate them as suspects when diagnosing wide-range of electric water heater problems.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 07, 2012 | RELIANCE ELECTRIC WATER HEATER
2000 galant has no acceleration,can only drive by touching gas pedal
Check operation of throttle position sensor with a ohms meter through its range of movement. Resistance should rise or fall consistently through its range of movement.
Also check the condition of the following:
1) Spark plugs, leads and coils
2) Air filter
3) Fuel filter.
Nov 08, 2012 | Daewoo Cars & Trucks
Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Oct 09, 2012 | D-Link DAP-1360 Wireless N Range Extender
Im gettiting a E7 error code
The E7 fault code is telling you the electronic range control (ERC) is detecting a problem with one or more key on the touchpad. This fault code can be caused by a defective touchpad or the ERC.
To determine which part is bad you need a technician to test the touchpad with an ohm meter. If the touchpad is good the ERC will need to be replaced.
Feb 07, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Olympus EVOLT E-300 Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
