Question about Universal Remote Control Remote Control
Manual for ultravox remote controller model rc120
Need for codes on seleco tv
SOURCE: Codes for Universal remote.
You have to perform a quick search (although it might not be that quick) for the code. Proceed as follows:
IMP: Switch on your TV set.
1. Press the SET button and hold.
2. While holding the SET button press the TV1 (or another TV/AUX button) and release both buttons.
3. Press the SET button again. The red light is now bleeping.
4. Press the POWER button repeatedly at 1 or 2 second interval until your TV switches off.
5 When the TV turns off press the TV1 button again and you are done.
Hope this helps.
Posted on Apr 04, 2009
enov8
  • 53 Answers
SOURCE: Need Remote Code to program Sanyo TV for remote model RC24977-0
Try these (4 digit codes)
SANYO.............0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Posted on Apr 23, 2009
Bulldog AV
  • 52 Answers
SOURCE: lost universal remote controll manual, need tv code
Try 0017
Posted on Nov 23, 2009
frankzcomput
  • 268 Answers
SOURCE: DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Posted on May 23, 2010
  • 4 Answers
SOURCE: I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Posted on Feb 17, 2011
I have a rc120 remote universal, and i need code for tv videocon.
Try using code search. If a search through all codes stored in the remote control fails, your may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 17, 2017 | Televison & Video
Codes
To which device do you want setup codes. Provide more details please. If you wish to get more details, check this site.http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Check this site too. http://electrohelponline.blogspot.com/
Check only for codes to your device by brand name. Not by the remote brand.
May 01, 2013 | Universal Remote Control Remote Control
I have an ultravox 32 inch tv and forget the code
048,028,017,022,000,007,073 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | Minka RC120 Remote Control
Need code for sky remote to work with sanyo tv model number CE32LC4-B please?
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 4 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
  • If this works try the other TV functions.
  • If these work then the correct code has been selected.
  • It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
You can also Visit Sky's Official Remote Code Finder.
Common Sky Remote Codes for your TV
(For a more comprehensive list see our Sky Remote TV Code Checker)
Aiwa 0106
Akai 0098
Akura 0042
Alba 0043
Amstrad 0063
Baird 0117
Bang & Olufsen 0118
Bpl 0115
Beko 0125
Beon 0899
Brionvega 0147
Bush 0157
Crown 0225
Daewoo 0092
Decca 0244
Dual 0257
Ferguson 0293
Fidelity 0294
Finlandia 0296
Finlux 0297
Fisher 0154
Funai 0179
Genexxa 0330
Goldstar 0056
Goodmans 0335
Granada 0340
Grundig 0345
Harwood 0361
Hinari 0365
Hitachi 0145
Itt 0384
JVC 0053
Loewe 0442
Matsui 0477
Memorex 0037
Metz 0491
Minoka 0921
Mitsubishi 0150
Nei 0514
Nikkai 0528
Nokia 0536
Nordmende 0537
Orion 0549
Panasonic 0051
Philips 0081
Pioneer 0166
Protech 0595
Pye 0600
Roadstar 0625
Saba 0645
Saisho 0649
Salora 0651
Samsung 0060
Sanyo 0159
Schneider 0665
Seleco 0672
Sharp 0093
Siemens 0680
Sony 0000
Soundwave 0702
Tandy 0741
Tatung 0049
Techincs 0250
Telefunken 0757
Thomson 0771
Thorn 0772
Thorn-ferguson 0936
Toshiba 0156
Visit Sky's Official Remote Code Finder for your TV here.
Click the link to download a PDF containing more Sky Remote Codes
Ask for help finding a code for your television here Sky Remote in our forums.
Jan 19, 2013 | Televison & Video
I HAVE AN ULTRAVOX 14 INCH AND I DONT REMEMBER THE CODE FOR RC120 UNIVERSAL REMOTE. ANY HELP? THANKS
google the remote model # and type in codes after the model and should pop up all the codes for you remote and should solve your problem :)
May 10, 2011 | Minka RC120 Remote Control
Hope this helps.
Jan 14, 2009 | Minka RC120 Remote Control
Need codes for Funai TV from Ultravox RC120
i need the leaftlet of this remote control rc120 for i lost it to put the number for the tv please can you help me Mary from Malta thank you
MinkaAire RC120
Fiddling around with the wall switch and remote control settings caused the receiver to suffer a mental breakdown. You may have to purchase a replacement receiver and reprogram from scratch. In practice, you generally have to decide whether to use the wall switch or the remote control, but not both.
Nov 22, 2017 | Minka RC120 Remote Control
T v remote
I have got am RC 120 Ultravox remote controller and don't have a code for an ANWA 14 inch tv.
Sep 09, 2007 | Televison & Video
Universal Remote Control Remote Control Logo
655 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
