Dear................. Please help! My nokia 2760's battery runs down whiles the phone is on standby and no application is running. I don't think its the battery cos it works perfectly on other types of the same phone. Thanks a lot for your kindness
Jst call ur service provider and ask thm to send u the settings required to run th java applictions fr ur nokia c3.. and also ask thm which setting should u make ur default as u might recieve more thn 1 settings frm ur service provider :D
Your phone has been infected with virus.I also had the same problem.Please enter *#7370# on your phone and restore settings and your problem is solved.Please don't forget to rate me as ' helpful ' if satisfied.
im sad to say that opera mini is not compatible with your phone and your phone is quite old so most of the new application wont run on it.... you cant run applications that are not compatible with your phone.... so please check the compatibility list before installing/downloading the application to make sure that it will run in your phone....
akuma_ryu21 don't forget to rate.. i hope that i helped you..
hi, how is the battery? are you sure the battery is in good condition and it is well charged? the reason why am asking is because, if the battery is bad you could be experiencing what you are experiencing right now...Also, have seen cases whereby phone will just go off and on because their are alot of applications on the phone. Although some of these application would install well while you were installing them but they may be too powerful or not really compactable with the phone...so, in cases like this, you need to delete some appliactions that you realise could not be to compactable with your phone..
lastly, it could be virus...if you browse the net regularly with your phone, the possibility of the phone been infected with virus is very high..try run scan on the phone.
Hello
You can try to do a hard reset to restore it back to factory settings. All your contacts, messages, calls, applications, themes > everything will be gone. So BEWARE. Backup your important stuff first. Your memory card will be fine, so anything there will be saved. However, if you have applications installed on the memory card, I recommend deleted those as well.
I always tell people to install applications and themes on the phone memory always! Your phone will run faster, as will the applications. Leave the memory card for your media.
Anyways, to perform a hard reset on the Nokia E71 you do this...
Type *#7370# from the standby screen while your phone is on.
It will ask for the lock code which is 12345 unless you have previously changed it. Make sure you do this right, because if you do it too many times the wrong way you can lock up your phone.
And that's it. Have fun re-installing all of your applications and themes.
Hopefully this helps you out if your having problems, or if you just want to clean out your phone.
Hope this helps.
It will be good to remove the memory card and check for errors/virus Use a good antivirus to scan and clean the memory. Remove off the bad files and keep back only safe ones.
remove battery and keep away for 15 minutes, then put back memory and battery.
Now clear out all the SMS, both text and multimedia, from the phone.
If possible reset the phone to default factory settings by using the phone settings- reset factory settings- type 12345.
Once cleared the phone should work or else there can be fault in the phone software which may need the assisttance of Nokia.
Hope this advice helps.
Hey there actually i also had the same problem but a minute ago so a review in the site http://cdpsolutions.blogspot.com/search/label/Nokia%20N73 and it said that formatting my cell with the number *#7370# would help if no try doing the other way of formatting that is : switch off your mobile phone and simultaneously press 3 keys that is green dial, star key (*), and no.3 key while pressing all these key switch on your mobile the factory settings will be restored or as to say your phone will be fresh as new, JUST DO REMEMBER TO TAKE A BACK UP OF ALL YOUR REQUIRED DATA because mine got deleted few minutes ago. hope this works, take care gob bless bye
hi!
may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
