Question about Zenith Televison & Video
Zenith XBV443 does not read picture cd Just 5 minutes before it read the same cd
  • Zenith Master
  • 19,396 Answers
Try using a lens cleaner cd.
Posted on Aug 26, 2008
  • Ginko
    Ginko Aug 26, 2008
    If it only happens with always the same cd, then the cd is faulty, bad recorded or scratched.
    If it only happens with photo cd then there is something wrong in the way you are recording photo CDs, or the software/hardware you are using to record photo cds is not compatible.
    If it happens with most CDs and dvds then it is usually a dirty lens problem.Try using a lens cleaner cd.
Zenith XBV443 no picture or sound after reading DVD disc
see this causes and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Sep 30, 2012 | Zenith XBV443 DVD Player/VCR
DVD has no picture or sound after reading
1) test the output cables from audio +video, clean it the contacts terminal from DVD to TV from oxide, corrosion.
2) test if the cable is faulty proove in another devices. and replaces
3) clean the objetive LENS with disk cleaner or use cottong swab with special liquid cleaner.
4) if the problem persist the problem will be in OPU + ampLifie Out audio associates circuit.
Go to the repair shop TV. for fix it.
God bless you
How do I exit progressive scan mode?
hold stop button down on remote for 5 to 10 seconds this resets progressive scan
Jan 10, 2011 | Zenith XBV443 DVD Player/VCR
Need a manual for a Zenith VCR/DVD combo Model XBV443
HOW DO I REMOVE THE FEATURE SHOWING "SUBTITLES AND DIALOG?
Nov 02, 2010 | Zenith XBV443 DVD Player/VCR
Hearing static while the dvd is playing how would i go about cleaning it
I have the Zenith XBV410 (combo dvd/vcr). I cleaned the lens using the Maxell Lens cleaner kit but nothing happened. Then I ran the Progressive Scan Mode and that seemed to do the trick. Word of caution: Progressive Scam Mode is difficult to turn off so would recommend you remove dvd from player, then press and hold the stop button for a min of 5 seconds up until whatever it takes to disablel PSM (Progressive Scan Mode)
Dec 27, 2008 | Zenith XBV443 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Owners manual for zenith zry316 DVD/VCR
http://www.retrevo.com/support/Zenith-XBV443-DVD-Players-manual/id/374dj499/t/2/
heres the manual you needed.Thank You for asking us.Please do rate if this solves your problem.
Sep 22, 2008 | Zenith XBV443 DVD Player/VCR
ErroR Message
Is it a DVD you burned ? Does every DVD do this ? Do commercial DVD's work ?
Sep 13, 2008 | Zenith XBV443 DVD Player/VCR
Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
56 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
