Question about Sharp Microwave Ovens
LIGRT BULBS BLOWN WHERE TO BUY NEW ONES SHARP R9320 MELB AUSTRALIA
  • Milton Croysdale
    Milton Croysdale Nov 23, 2009
    phone No 93216069 nth melb
  • Sharp Master
  • 9,098 Answers
These bulbs should be available at most grocers, home improvement stores, hardware stores, or appliance parts stores.
Otherwise you can find Sharp spares here and support here.
Posted on Sep 02, 2008
Sharp microwave model R-218H(s) is not working
take it in for a proper diagnosis and quote
if it is serious it will be cheaper to buy a new unit
Jul 16, 2016 | Sharp Microwave Ovens
Blown light in sharp microwave
there are quite a few light bulbs available
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
enter your model number into the search field
Aug 06, 2008 | Sharp Microwave Ovens
Sharp R1480 OTR microwave night and work light won't turn on
Check you are getting 115 V with the bulb in circuit (safest way to test this is to solder a couple of bits of wire to one of the bulbs so you can access the terminals with the bulb inline (be careful), and then measure voltage across it.) The load imposed by the bulb may be causing the power supply to go into a protection mode - usually only if bulb is shorting, but may be a problem with the power relay. If there is a problem with the power supply, through the control board relay or otherwise, this will tell you for sure. Otherwise, if there is definitely the right voltage to a good bulb, then it will light. Check that the bulb is definitely making contact well, and make absolutely sure you have the correct bulbs for 115v, not the 220/240v ones. If this gives you no luck then please ask again with details of what you found. Hope this helps :)
Aug 16, 2007 | Sharp R-1460 Microwave Oven
Scrambled display on Sharp Microwave Model R-350C
this will be the display cpu its a very tricky repair as the cpuhas around 15 very small wires that have to be desoldered and resoldered to the new cpu best done by someone who is uesd to fine soldering,
Dec 11, 2012 | Microwave Ovens
Sharp r-580d microwave lcd not working
We regularly repair these for $39.95 for US customers, but with extra shipping, that would double to ship it back to Australia.
Otherwise, you can find local servicers from Sharp Australia support here.
Nov 27, 2012 | Microwave Ovens
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
Motor will not operate
Found spare parts supplier on web thank you. Hopefully it will be the correct turntable motor - otherwise, I will just have to buy a new Microwave.
PR
Jan 27, 2010 | Sharp Microwave Ovens
I have a sharp r1480 microwave. the work lights do not turn on. the bulbs are good,and light buttons beep but no light.
listen for a click not just a beep, if it doesn't click the relay is bad on the pc board, if it clicks the trace may be blown to the relay
Jan 26, 2010 | Sharp R-1480 Microwave Oven
Spare parts search ProlineST44 Microwave
your after what i call in australia, is a high voltage fuse, readily availableeither online or from any electronics spares dealers.
Jul 06, 2009 | Sharp R-242 Microwave Oven
Sharp carousel r-1481
Ceramic fuses of 15A or 20A rating are available at home improvement stores like Lowe's, places like Wal-Mart and local appliance stores.
Ceramic fuses are preferred because they are considered flameproof.
Nov 04, 2007 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
