Question about Raymarine C80 GPS Receiver
Raymarine C 80 Head up problem
C 80 will not work in head up mode.
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Posted on Aug 29, 2008
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
C 80 screen has gone black,cant read infro, Bermuda
If you peer into the screen can you make out anything on it like as if the back lighting is bad? Also it may be set to night mode as well. You can try a factory reset. I have seen their screens go bad from time to time. If none of the above work. Send it in to Raymarine.
Feb 24, 2010 | Raymarine C80 GPS Receiver
Photos print with a faint 'pinstripe' effect
that could be head alignment (most noticible on low quality settings .. there is a procedure for aligning the heads ... or it could be clogged nozzles
to check these things start to print something
then select preferences .. then maintainence then
you have a choice .. nozzle check should be done first .. if all nozzles are working then go to "head alignment" and follow instructions there .. if some nozzles are not working then run the "cleaning" utility . sometimes it needs to do that several times .. if you cant get all nozzles working then you can try "deep cleaning" that uses lots of ink so you dont want to do that often ... if that doesnt work then you need new heads .. the heads in many pixma printers are easily replacable but costly ..
if all the nozzles are working and head alignment was done but you still have faint lines then try "high quality mode" .. in that mode you should not see any lines ..
Dec 23, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Can i connect nmea outputs from a raymarine e-80
yes, you need the NMEA out cord set for the E 80 and hook the output of the E series to the input on the power data cord on the Garmin - out to in
Sep 30, 2009 | Garmin GPSMAP-640 GPS Receiver
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
My Raymarine ST6001+ says no signal. All other instuments are getting good GPS signal. I have have changed compass but nothing changed. I have a Course Computer 400 as the main autopilot controller. Can...
if the ST 6001 shows "no data" and alarms, the course computer is most likely bad. Control head failure is very uncommon, hower you should look at the brain box (T400) and move the control head to the other seatalk terminal (there are two) you may have just one failed SeaTalk port and can use it as is, otherwise, Raymarine will still fix (this week) 847-746-0100
Jul 11, 2009 | Raymarine St60 Plus Package, Includes...
Scanner not reponding - Checking HW
1.try with a new software 4.29
if you have an old one like 2.14 you have a problem.
2. After this try you C 80 on a nother boat or Raymarine dealer
than you will know if the C 80 works
Jun 20, 2009 | Raymarine C80 GPS Receiver
Problem getting a proper fix
The antenna should be replace by raystar 125.
Regards
Michel
May 31, 2009 | Raymarine RL70CRC GPS Receiver
Have a 50/200khz xducer installed in the boat. The raymarine L265 head failed. (non repairable) would like to use a compatable head Question - are there pig tail cable adapters avail or connectors avail to...
Hello bhowardjr,
Yes any electronics store would sell a cable conversion kit what you would end up doing is putting a matching socket and jack arrangement on each end and connecting them. You just have to find the matching cable ends.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 05, 2009 | Raymarine Boating
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raymarine C80 GPS Receiver Logo
181 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
