How do i size a residential gas boiler? - Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Depend on what part of the country the standard for r-values for homes are! Check a reputable contractor or better yet, call the city mechanical inspector for the correct Btu's per sq. footage of dwelling or establishement! Thank-you-very-much!
Posted on Aug 26, 2008
Why does pilot go out after 1 or 2 days' operation?
Sounds like thermal couple needs cleaned or replaced, not a expensive part. press the helpful button and check link below
No Hot Water How to Replace Thermocouple
Jan 16, 2016 | Crown AWI162S Aruba Residential Standing...
Tip
Peerless boiler
This boiler us one of the best on the market!
on Sep 23, 2013 | Peerless G63-03W Residential Hot Water Gas...
What would cause my weil mclain oil fired furnace to lock out? any help would be greatly appreciated thank yo. . Charlie
Could be the photocell (CAD cell) on a residential boiler, or a fuel problem ie dirty fuel filter, oil lines losing prime.
Mar 15, 2015 | Heating & Cooling
Boiler will not reset
Check the induced draft pressure switch's tubing that connects it to the induced drat assembly, the barbed port that the tubing connects to gets clogged requiring reaming annually or this will happen, if this does not work replace the switch, make sure to clear the port.
Dec 07, 2013 | Lochinvar Energyrite Residential Heaters...
Unit not coming on. There is water, gas, and electric. I can adjust digital read out for water temp, but unit is non responsive.
have you reset boiler and gone through start up procedures.if so it sounds like an ignition problem? you need to explain what happened before you adjusted the water temp and why?
Dec 11, 2012 | Rinnai 351-R50LSiN - Water Heaters -...
How do i increase the water pressure in my gas boiler
Check the sand filter is not blocked
Check the pump size is ok for the filter size
Pit your multiport to recirculation to give the boiler full pump presure.
You may have a pressure switch fault
Oct 09, 2012 | Lite On Laars Lite 2 Heaters: 250,000BTU...
What's your problem?Power vent starts, unit will not fire up. Red light on board flashes steady.
Water heater and type of gas valve are not identified.
Add a comment and describe the 'board' you are talking about, and include brand and model number of water heater shown on label on side of tank for possible identification.
If this is a boiler or commercial water heater, then repost question for another expert.
First step for residential water heater is to identify gas valve to download error codes, and possible service manual.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 25, 2011 | Water Heaters
I have a residential gas service from PG&E. What is my maximum heater size? PG&E said the maximum output is 250,000 btus. I have a 90,000 range and a 50,000 btu hot water heater. Does that mean my...
I take it we are talking gas meters here , if so meters only pass so much gas, to there size so 250,000 is the max it will pass for that size meter if you need more you can have a bigger meter fitted , but this would cost you i would think ,so yes 110,000 is what you have left in btus on that size meter
Jul 31, 2010 | Williams 3003622 Ceramic Wall Mounted...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
