Question about Microsoft Windows XP Professional
No display after pressing the power buttton, the lights and fans are all runs but it doesn't display anything on monitor. We have check all the connection and reassemble the whole system but still its the same
    Sergeant:
  • 241 Answers
Was you display acting strange before this. If so that could be a internal problem with the display (this is a common thing for older CRT monitor) the good news it can be repaired.
Ok that's the worse case Try booting in safe mode and then see if the lets you view you monitor.
If Yes cool If No
Try to unplug the monitor ALL plugs then you can try and different monitor (if you have one) and if that too doesn't work then you at least you know where the problem is.Now try replugging in the OG
display.
Still no luck
then try from another computer go on-line find model get a (driver)
copy it to a disc and install that . You will have to go into BIOS to configure you boot sectors.
Posted on Aug 28, 2008
Does not switch on but power on light is on
I would remove the battery, power supply, RAM and hard drive. Plug the power supply in and see what happens when the power button is pressed. If nothing, there is a motherboard issue, possibly a GPU error. If it comes to life, re assemble bit by bit until the culprit is found.
Jan 14, 2014 | Computers & Internet
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Apr 21, 2012 | Compaq Computers & Internet
My Dell Optiplex gx260 Pentium 4 Flat CPU doesn't Display anything, and Power light is Orange.. Please help me out
You say the power light is orange--I'm assuming that you mean the monitor.
This indicates the monitor is not receiving a signal from the computer.
Assuming that the computer actually powers up (fan runs, you can hear the hard drive being accessed, etc) then your problem lies in the video card.
If, on startup, you do see the BIOS info and maybe even the Windows splash screen before your monitor goes dark, then the problem lies in the video card drivers. In this case, starting in safe mode will work and allow you to download and install new drivers.
Aug 27, 2011 | Dell OptiPlex GX260 PC Desktop
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
When I try to turn my computer on, it won't do anything. All I see is the gold light blink in the lower left corner.
Hi mcfarlandger,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5330-2339 Notebook
Toshiba m100 my hand trying to have a power LED and battery LED fan works but I can not display the image signal.
Hope this helps.
Jun 03, 2011 | Toshiba Satellite M100 Notebook
Power shut off automatically
problem in motherboard.Try engineer to repair it.
Aug 26, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
