Question about Insignia Bluetooth Wireless Behind-the-Head Headphones - Black
Won't charge or turn on.
I've had these earphones for a while now, and they've worked great the whole time. I've taken good care of them, and they are practically like new. But from one moment to the next, they won't turn on. When I plug it in to the charger, the insignia logo flashes red once and goes dark. Anything I can do?
  • 1 more comment
  • lukeyg232 Oct 11, 2008
    I cant even get it to charge.... i plug it in and there is no red light.. and when i try to turn it on it wont give me the beep SOME ONE HELP ME PLZ!
  • crj2000 Oct 13, 2008
    This is exactly my problem. I have opened mine in order to check if it could be a broken or loose wire, but no success.
    If someone has a solution, please write me too: crj@pop.com.br
    Thanks
  • Anonymous Jan 25, 2009
    Yeah, Power-Then VolUp&VolDown works perfectly! I've already downloaded few datasheets to read about, and then got the solution here... Fuhhhh :)
I wrote to Insignia and they recommended the following procedure, which worked for me:
1- Plug the charger into a power outlet
2- Press the Volume Up and Volume Down buttons at the same time for resetting the device.
My earphones are working well now.
Regards,
Celso
Posted on Oct 16, 2008
  • 18 Answers
2- Plug the charger into the headset
Posted on Dec 28, 2008
This worked for my headphones, when I first purchased them: Thank you for contacting Insignia Products about your NS-BTHDST,Insignia
Bluetooth Headset.
I'll do my best to assist you,so you can start enjoying your product right
away!
According to the issue you described, I'd recommend you to try the following:
1- Turn on the computer and plug in the USB bluetooth adapter and then restart
the computer.
2- Make sure the headset is off and press and hold the multifunction button
until the blue and red lights flash alternately.
3- Open up MY BLUETOOTH PLACES and click on VIEW DEVICES IN RANGE. check if
the NS-BTHDST appears listed. If so, right click on it and click CONNECT. At
that time, you will be asked for the bluetooth password which is 0000 (four
zeros).
4- If the NS-BTHDST does not appear listed, click on SEARCH FOR DEVICES IN
RANGE. Once the headset is found, attempt to connect.
If the product works for music, but you cannot get it to work to chat, please,
refer to the software manufacturer (Yahoo,etc) or the computer manufacturer.
Perhaps there is some configuration you have to change, since the product is
working fine for music.
I hope this helps, but just in case you need further assistance, remember you
can always contact Insignia Products Technical Support at 877-467-4289 and
provide the agent with your case number: 3100497
With this number he will be able to see my notes and assist you faster.
We are 24/7 so you can give us a call any day any time!
Posted on Oct 28, 2008
Yeah, if you would have looked at the posts in front of you, you would have seen that if you plug the headphones in and then hold down the volume up and volume down buttons at the same time it "resets" the headphones. You then should be able to push the power button and have them come on. I thought my headphones were done and now they work just fine.
Posted on May 09, 2009
Same problem, not charging or turning on. Pushing the volume up and down at the same time then pusing the multifunction button to turn them on worked for me. Working fine now. Happy to have them back. I love these and use them every day. I don't have the receipt anymore from BestBuy so I couldn't return them. Was really bummed out but it works now! :-P
Posted on Feb 11, 2010
I just got these headphones too and after a week they wont turn on. i hold down the power button and nothing happens. when i plug them into the charger they will charge because i can see the insignia letters light up in red, but then they just wont turn on.
Posted on Sep 04, 2008
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
Croc flat iron won't turn on
You might visit www.flatironrepairs.com and contact them to see if they could repair it. It's only $46.00 for the repair + s/h.
Dec 04, 2012 | Crocs Croc Infared Flat Iron 1"
I have an 86 cutlass runs great, however I'm having some electrical problems. The tail lights won't come on and if they do they won't turn off. I've replaced the alternator and the b
can i suggest you kill it !!!!!! sorry but there is a draw on the battery ,,,, disconnect each item one at a time till battery dont spark at lugs when you disconnect them ,,, seriousy loossen lug on battery and if no power draw no spark wil be present... maby alittle one cos radio takes a really small current
Feb 12, 2012 | 1986 Oldsmobile Cutlass Supreme
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
My Nikon Coolpix s550 won't turn on despite having charged the battery. I went out and bought a new battery from Best Buy today and tried to get information on what might help but, surprise, the guy...
refurbished items sure have hidden defects/problems that later contributes to malfunction. i think, one of its internal chips(techy things inside) has worn out... probably needs replacement.. i suggest look for a technician.. if you're living in the philippines,it's easy to find someone. you can save your lovely camera and lil money of course.
Jun 19, 2011 | Cameras
Alright so I have a Logitech webcam C160 and I've used it plenty of times now and I've taken good care of it. The problem is when I plug it in and go to use it, the green light flashes then turns...
I would go to control panel, bring up devices, and attempt to rollback driver, reboot and test. If this did not work, verify there are not two drivers assigned to port - open device manager again off System, then check device drivers. if two - remove the second one. If still does not work remove all drivers, uninstall all software through the add/remove programs, remove device, install software, plug in device, then reboot again.
Jun 13, 2011 | Computers & Internet
Sennheiser mm200 totally dead
Well I have had the same problem as well, twice really. The first one got replaced by Sennheiser, very good service. Unfortunately about a year later the same problem, I am waiting now what they will do with this. I really like the little earphones but I need them to work. Untill now I have had great service which of course comes with the quality of the name.
Sep 21, 2009 | Sennheiser MM200 Premium Bluetooth Stereo...
Insignia Bluetooth Wireless Behind-the-Head Headphones - Black Logo
1,882 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
