Question about Zanussi ZWF1430W Front Load Washer
Washing machine makes constant beeep beeep sound with 'end' led flashing
I opened top after the socket kept tripping i found a little panel with wires going and coming out of it had been detached the screw was on the bottom i got that out and screwed it back still does not go into wash mode
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ... > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
How to unlock the door
Lamp M flashes slowly when the appliance is switched on and
a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme.
24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board.
If the door is constantly locked then you can access to interlock by removing the top cover of washing machine.
Aug 17, 2014 | Ariston Technologies Ariston AWD12 Front...
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
I have an NEC nwtl656 top loader. It will not perform any function as every attempt at choosing a wash setting results in it sounding a beep and flashing all lights on the panel. No washing settings make...
Hi Mark, my friend has one of these machines and we had troubles like that, in the end i found out the "out of balance switch" was a little sticky. You find the switch by opening the back panel and it is lockated on the right side in the top corner. I flicked the switch a few times to hear the klick-klack, and that was it. Turned it on and it worked perfectly. Maybe it helps, good luck. Hebie
May 05, 2011 | Washing Machines
My machine stopped and made a constant beeping while the 3rd, 5th, 7th & 8th lights across the top remained on. What does this mean????
It sounds like this is a Fisher and Paykel-made top load washing machine and you are referring to the Wash Progress LEDs. The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right hand rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB swicth bypassed. Replace the Motor Controller Module if that is the case.
Mar 22, 2011 | Washing Machines
The most common cause of this is the sensor wire inside has vibrated loose and is no longer making a connection to the switch. Those switches rarely fail. It's a very easy fix, only need a screwdriver. I would, however, use a small plastic ziptie to hold the wire to the switch.
Oct 06, 2009 | Hotpoint WMA64 Front Load Washer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Jan 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
