Question about Toshiba Satellite A135-S4527 Notebook
How do i install audio output device
I can not get any sound when i try to play a dvd and beside the volume icon its saying no audio output installed
  • 10 more comments
  • adeolamide20 Aug 26, 2008
    I instal window XP professsional in my laptop ,after which I can not get any sound from my laptop,also my wireless network adapters did not work.
  • janskippers Aug 26, 2008
    do not get any sound to play music or dvds
  • Anonymous Sep 11, 2008
    the audio icon is telling mee that there is no audio output device install
  • Anonymous Sep 27, 2008
    IN MULTIMEDIA FILE IT SAY NO AUDIO DETECTED
  • drnidhigupta Oct 07, 2008
    i donot get a sound in my laptop when i play, it says no audio output devise installed, wat to do? how to install audio output device?
  • Anonymous Nov 06, 2008
    same problem
  • martin mcallister Nov 20, 2008
    I have lost my audio devices.laptop says no audio devices.fujitsu siemens
  • Anonymous Nov 29, 2008
    How can I solve the issue of getting the same message (no audio output device is installed). My Toshiba Sattelite U-305 S 5077.
    Can someone help me to solve this problem?
  • dirain_90 Dec 08, 2008
    i have uninstall my audio device from my lap top,but when i install back..the device can't to install..how can i solve that problem????
  • luke-321 Apr 11, 2009
    there is no sound at all please help me i need it!!!!!
  • cozmofun May 11, 2010
    i can not get any sound when i try to play a dvd and beside the volume icon its saying no audio output installed
  • Ravi Kumar
    Ravi Kumar May 11, 2010
    First, get back with the Product Number or Model Number of the notebook is so that we can try finding the required drivers for your Notebook...
Problem remain
Posted on Jan 01, 2014
I do install windows seven on my toshiba satelite laptop after there is no audio driver found,, so there is no sound out put any way...what shall i do
Posted on Apr 30, 2011
  • 4 Answers
For further information visit http://pcguideforyou.com
Posted on Jun 12, 2010
Hi!
Thanks alot! Just got my sound back! This was by using the device manager-Windows+Run,etc
Charles,Kampala-Uganda.
Posted on May 18, 2009
    Problem Solver:
  • 10 Answers
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
how do i install audio output device - attachment.php?s=d074f1b3c70781e9f502ecfeec63067c&attachmentid=21&d=1203095937
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Posted on Aug 27, 2008
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
No audio output device installed
Under sounds no audio is installed, scan for hardware changes, still no luck try this: Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. Check device manager for audio, scan for hardware changes. reconnect to tv.
Nov 06, 2012 | Computers & Internet
No audio sounds
Hi Jay,
When was this happened, after you've notice that there was No Audio?
Check on the taskbar first, on the lower right corner look for the speaker icon. Check if there is red cross out circle on it. If so, your sound is only muted, Un-check it! Now, If you are using Headset/Monitor try to adjust the volume into higher one(as max as you want) to check if the problem is only on output source/accessories. Or maybe, audio driver was not installed in your computer. Right click your My Computer and hit Properties > Hardware Tab > Device Manager see if theres is Yellow Question mark beside Speaker icon. Then you must update/install the accurate sound driver for your computer.
Thanks
Feb 24, 2011 | Computers & Internet
The volume on my computer is not working
Try installing the audio driver again, if you do not have this driver on a CD, then you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jul 23, 2010 | Compaq Presario Notebook
No Audio Output Device is Installed
Go to the following webpage: http://support.microsoft.com/gp/no_sound & run the automated troubleshooting service for sound by microsoft, there is a good chance of your issue getting resolved....
Jul 23, 2010 | HP Pavilion DV9500Z Notebook PC
Have you tried reinstalling the sound driver? if not, click on start, then click on search. type in device manager, then press enter. click the arrow next to sound, video and game controllers. Double click on High Definition Audio device, if it says that the drivers are not installed, click on install drivers.
hope this would help.
Jul 19, 2010 | Microsoft Windows Vista Home Premium with...
Volume icon on taskbar says no audio output device is installed
Hi there.
You need to install the audio drivers so you hear the audio.
Please post the make and model of the computer so we can direct you to the appropriate driver download.
Regards
May 26, 2009 | Gateway Computers & Internet
I can't hear voices when i play a dvd on my computer, just background sounds. i've tried many different dvd players (windows media, apple, etc) and have also checked my settings for mono or stereo speakers...
You should also check your DVD playback software and make sure that you have it set for desktop/laptop speakers and NOT for something like 5.1 or 7.1 surround etc.
Jan 03, 2009 | Computers & Internet
FDISK my drive and re-installed Win XP. I have no sound.
try the following steps. 1. Right click My Computer Icon and select properties then select Hardware tab. 2. After selecting hardware tab click Device Manager button. 3. After clicking it list down all devices that you have and expand the  "Sound Video and Game Controller" by click the clicking the plus(+) sign and it shown you the list sound devices. 4. In the list, look for explanation point(!) in yellow color beside device name (this means that device driver is missing or not properly installed) 5. Select the device name and press right click and choose uninstall. 6. After uninstallation click Action Menu and select "Scan for Hardware Changes" (this will scan the other device which is not yet installed in the system) 7. System will prompt you to load the Audio driver(insert the Audio device cd driver) if your using a built-in audio use your desktop/laptop device driver cd and locate the driver folder from cd and choose sound or audio folder the list and select the proper windows for your computer. 8. after running installation the volume bar should appear  in the right side of your desktop allong with computer date & time. if not restart your computer.
Nov 20, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite A135-S4527 Notebook Logo
3,129 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
