Question about Datacard SP55 Printer
Pickup roller How do I get inside the printer to change the pickup roller?
First you need to get the Blue perspex cover off the Lid by pulling it from the rear. After juggling it off the cover needs to be removed from the base by bending it outwards to release it from its catches. when the outer case is removed from the base you will then need to release the PCB from the base (leave it sitting on the base) to allow you to remove the card hopper, this unclips from the bottom edge.
you now have access to the Pick Roller. You will need a long T12 (Torx Screwdiver) to remove the 2 x screws which hold the Pick Motor in. When the Pick Motor has been released you can replace the Pick Roller (ensure the roller is the correct way round)
Posted on Sep 04, 2008
What are the causes of jaming
Jams are most commonly caused by worn rollers in the paper pickup area. One roller is in the tray and there are two rollers in the body of the printer above the tray. The blue rollers are the feed and separation rollers, the while body roller is the pickup. You can try cleaning them with a damp cloth but depending on page count they might be too worn. Part numbers are Pickup roller RM1-0036 and feed/separation rollers are RM1-0037. If the printer makes a lot of noise when printing then it is possible that the fuser drive is worn and causing slipping.
Feb 07, 2015 | HP LaserJet 4250n Printer
How do i clean the rollers on my printer?
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Aug 10, 2014 | Dell 1720dn Laser Printer
No paper pickup, Press check
1. Push the paper far inside / use the priority tray.
2. Check for deterioration of the rubber on the main pickup roller (Replace if needed).
3. Ensure that the main paper pickup roller (view inside the printer from the priority input slot - use a torchlight) is rotating when print command is given / 'check' button is pressed after the error message.
4. The printer will make three attempts, one after the other, to pickup the paper (you should be able to hear the sound of main motor and gear train rotating - if no sound is heard the main motor / gear train is bad).
5. If the paper pickup roller does not rotate - a component in the gear train needs attention / replacement.
6. The gear train is behind the formatter inside the right side cover.
7. Service manual can be downloaded free on the net.
Mar 05, 2014 | HP LaserJet 3055 All-In-One Printer
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
Tis can't pickup the paper and its making noise
If your printer can not pick up the paper then you need to change the pickup roller and separation pad. You need to get the preventative maintenance kit RK-1320, this has the roller, pad and transfer roller. It is available:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
Oct 16, 2012 | HP LaserJet 1320 Printer
Printer out of paper
i discover a paper was jamed and hooked on the roller film which was not allowing the printer to take paper. so i removed the paper and change the bad roller film. now my printer iss working fine.
thanks
Jun 30, 2009 | HP LaserJet 3330 All-In-One Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
Rollers are leaving black smudges on my checks
Are you positive that this is a 'roller' problem.  Black smudges usually indicate a drum problem (your toner cartridge).  If you pull it out, you'll see a flap that should move back and forth.  If you move that flap, you'll see a shiny cylendar.  That's the drum.  See if you can see any marks on it (don't touch it with your hands.)
The problem is, it's hard to tell whether or not it's the drum just by looking.  Your best bet is to see if replacing the cartridge takes care of the problem.
Oct 26, 2007 | HP LaserJet 1012 Printer
Datacard SP55 Printer Logo
283 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
