Question about Olympus EVOLT E-300 Digital Camera
LCD monitor Can I control brightness in the LCD monitor?
    Master:
  • 852 Answers
Yes, you can control the monitor brightness up to +/- 7 steps.
Posted on Sep 04, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
Mar 25, 2010 | Acer 22" X223w LCD Monitor
E196FP monitor brightness controls do not work
It an happen due to moisture, Temp solution unplug the cables and take it near a light to just give a mild heat and then reconnect.
Feb 19, 2010 | Dell E196FP 19" LCD Monitor
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
Screen So Bright I Can Barely See Anything...
Unfortunately the problem is the monitor has gone bad, more specifically and likely is the backlight which is used to light up the monitor. You could fix it by replacing the LCD, but you can get monitors cheaper than a replacement LCD so it wouldn't be very cost effective to do so.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
Monitor is too bright
Lcd monitors do not go overbright due to aging,they may go dim due to backlight aging.Do front panel controls work and if so what happens when you try to bring down brightness?
Some monitors have a "Recall" function which is a factory restore bringing all setting to factory value.
Try this if available.
Samir
Mar 07, 2008 | Gateway FPD1760 17" LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Olympus EVOLT E-300 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
