Question about Olympus EVOLT E-300 Digital Camera
Will the camera automatically enter Sleep mode or turn off?
Will the camera automatically enter Sleep mode (standby) or turn off?
    Master:
  • 852 Answers
The camera enters Sleep mode over a certain amount of time when not being operated. You can select the time to enter the Sleep mode from OFF, 1, 3, 5 or 10 minutes.
Posted on Sep 04, 2005
I need help unlocking my zte t185
WAKE UP FROM SLEEP MODE • Press the Power key to activate the display. • Long press on the screen to unlock. • You can pinch out on the lock icon to get quick access to Phone, Email, Messages, Audio, Camera and Calendar apps. SWITCH YOUR HANDSET TO SLEEP MODE Press the Power key to activate sleep mode. Sleep Mode activates automatically with the timeout set from Options > System settings > Display > Sleep. TIP If you set an unlock pattern, PIN or password you need to enter it to unlock the screen. If you forget your pattern or PIN use your Google Account password to reset the phone. This will only work if you register a Google account with this handset.The above instructions ARE NOT for the FRP lock, which requires the Google Account information that the device was set up with. Were you asking about the FRP lock?
Mar 24, 2018 | ZTE Cell Phones
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
Jul 08, 2011 | Uniden CEZAI998 Phone
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Aug 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
It is not switching on
1. Please male sure that the battery is inserted in the correct orientation
2. For laptops, make sure you have checked the Power Options settings.
a. Hibernate should not be set.
b. Monitor, Hard Disks and System standby should be set to NEVER
3. For desktops, turn off computer's hibernation, standby, and sleep modes.
4. Turn off the camera
5. Connect the USB cable from camera directly to the computer's USB port
if the issue is not resolved, contact kodak at www.kodak.com/go/itg
Jan 22, 2009 | Kodak EASYSHARE M763 Digital Camera
Program copier not to sleep at work
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Sep 27, 2007 | Xerox CopyCentre C128 Black and White...
Olympus EVOLT E-300 Digital Camera Logo
119 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
