Question about Olympus EVOLT E-300 Digital Camera
Will the settings be retained in the camera after turning off the power?
    Master:
  • 852 Answers
Yes. The camera holds current settings including any changes you have made while turning off the power. If you prefer the original settings you can use the RESET function to reset to the factory default settings.
Posted on Sep 04, 2005
How to reset sony dsc-w90 to factory setting
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
Follow the appropriate procedure below for your camera. Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button:
Locate the RESET button on the camera.
Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset:
Turn off the camera.
Remove the battery pack.
Remove the button-sized lithium battery.
Allow the camera to remain without power for 30 seconds.
Reinsert the button-sized lithium battery.
Reinsert the battery pack.
Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Hope this helps.
Oct 07, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
How do I reset the camera.
Hi.
1.Turn off the camera.
2.Remove any memory card installed.
3.Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
4.Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
5. Verify if the camera works without an optional memory card.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained.
Thank you for using Fixya!
Nov 16, 2010 | HP Photosmart M22 Digital Camera
Digital Zoom and Auto Focus "On" settings are not kept/retained
If you shoot in the P mode setting and then go to the Menu and set the option for All Reset to OFF. The camera will retain those settings when powered off. If you are shooting in the AUTO mode the camera will always default back to the factory setting of OFF when the camera is powered off. The All Reset function is not able to be set in the AUTO mode because the camera is already using factory default settings.
Feb 24, 2009 | Olympus Camedia C-765 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Error 000000c8-8be7-586-053
Please, perform a camera hard reset. To do so, follow the steps below:
  2. Remove any memory card installed.
  3. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  4. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained. If the error message still appears after performing the camera hard reset, please click contact hp on this page for more support. CAUSE: The issue is caused by the Focus Home Sensor falling out of its position.
Nov 28, 2008 | HP Photosmart M22 Digital Camera
Custom settings disappear
This was already answered! See prior questions... indicates to go here for how to
http://www.pbase.com/ociepka/750
Mar 24, 2008 | Olympus Camedia C-750 Ultra Zoom Digital...
Burst mode
Turn on the power with the mode switch in the camera position. Press MENU to display the menu. Select Mode (REC Mode) menu item with the left & right arrow buttons on the control button. Select the "normal" setting with up/down arrow buttons. Press MENU to turn off the menu. I believe the pictures already taken in burst mode are retained in the camera. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 01, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Settings are reset
The camera can be set to retain all your camera settings each time the camera is turned off and on. Press the OK/MENU button. Then press the right arrow to access the Mode Menu. Press the down arrow to highlight the SETUP menu. Press the right arrow to highlight ALL RESET, and then press the right arrow again to highlight ON. Press the OK/MENU to save this setting and return to the Mode Menu. The camera will now retain any settings such as Quality each time you turn off the camera.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Camera reset
The D-390 allows you to choose if you want the camera to retain your settings or to default the settings. In the camera menu, there is a function called “All Reset”. If the selection is ON, the camera will default all settings each time the camera is powered on/off. If the selection is set to OFF, the camera will remember all of the settings that have been made.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Olympus EVOLT E-300 Digital Camera Logo
94 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
