Question about Cisco 7912G IP Phone
LEDS are lit- one red, one green. no display, no boot
We have several IP phones that are stuck at boot.
De red and green led continue to lit
Nothing in the display
Nothing happens at all.
Johanvt
  • 1 more comment
  • inigoml Sep 03, 2008
    Same problem.
    However there is DHCP activity. That is, phone is trying to obtain IP address although it does not respond to DHCPoffer from server
  • Anonymous Apr 05, 2009
    i have the same problem, i setup the tftp server put the pfone does not ask for the file.. and i dont have all the files neaded for the upload, where can i found the files?
  • Maren Radic
    Maren Radic Oct 19, 2017
    Problem is with hardware and solved.https://www.youtube.com/watch?v=hVEHyLFs...
SOLVED!
This happing when trying to download a firmware upgrade or config from server and there is a power outgage.
Solution:
Put a file called cp7912r.zup in your tftpserver root. This file can be a valid cisco image, for example, CP7912080001SIP060412A.sbin
Posted on Sep 03, 2008
I have had the same issue with several handsets returned to me. There was DHCP activity, but the handsets never requested a file - most sites have suggested you must specify option 150 in the DHCP settings and not 66 but I eventually tried 66 and hey presto - the phone requested the 'cp7912r.zup' file.
Posted on Apr 01, 2009
  • 48 Answers
So after encountering this exact problem on nearly 10 separate phones I inevitably found this thread. While alot of the information definitely helped me to find the solution, there is a few things that were missing.
HyperTerminal or Procomm will allow you to see the boot procedure/sequence. I was continually getting stuck at the DHCP response. You will also need TFTPD32, and have it set up per these instructions : http://www.planex.net/pdf/switch/sw-0208g_setup_eng.pdf
Norksman's Factory reset code is one of the reset codes, the other one that took some digging to find was this one:
3491672850*#
With all the proper files in place, TFTPD32 setup properly, Procomm to watch it's status, and this reset code, you should be up and running!
If not, you are more than welcome to send your phone to http://IdacomUSA.com and I would be glad to help ya out!
Posted on Feb 18, 2009
    New Friend:
Problem is with hardware.
Solution: https://www.youtube.com/watch?v=hVEHyLFsWHo&feature=youtu.be
Posted on Oct 19, 2017
Our 2 draw dishwasher stops mid cycle once or sometimes several times. The red light comes on and it bleeps until we press the start button then it will continues the cycle.
The red light and beeping indicates a fault. The fault code number will be indicated in the display or by other LEDs being lit. If you post back with the details of the display we may be able to help you.
Jan 25, 2015 | Fisher and Paykel Dishwashers
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
When I charge my Jazzy select 6 over night the off board charger lights turn from one red and one green to both green and yet the joystick indicator shows no charge.
I am assuming that the PWC runs and the batteries behave like there is a full charge. The performance of the Jazzy is good. If you have a volt meter you can check the voltage at the charging port but this is too difficult for the average user.
There is a battery display indicator (BDI) on the joystick that indicates battery charge through a series of LED lights. More lights, larger charge and higher voltage on the batteries. There are two reasons why the LEDs are not lit assuming the first two sentences are true:
1. The LEDs or the circuitry running them is burnt out.
2. The LED module has come unplugged from the circuitry.
The solution for both problems is the same. Open up the joystick case( if it is out of warranty )and inspect the LEDs and wiring. The easiest and most expensive way to solve the problem is to replace the joystick assembly. If you do nothing there is a good chance that you will get stuck somewhere because you do not know the charge state of the batteries. If it is under warranty your problems are solved. Call a qualified dealer in your area and have the problem component replaced.
Hope this helps.
Oct 31, 2010 | Pride Jazzy Select 6 Indoor Power...
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
CISCO 2600 Router Troubleshooting
This is the indicator configuration for the 2600, if the lights are yellow there is a problem.
The following indicator LEDs provide power, activity, and status information:
POWER (green)—Lit when power is on
RPS (green)
Off—No redundant power supply (RPS) is present
Blinking—System is booted, RPS is present, RPS failure
Continuous on—System is booted, RPS is present, no RPS failure
ACTIVITY (green)
Slow, steady blinking—System is booting
Blinks during system activity, such as interrupts and packet transfers
I suggest going to Cisco.com for full documentation on this product.
Feb 19, 2009 | Cisco RPS 22/18 (cab-rps-2218)
No display
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Feb 18, 2008 | NEC MultiSync LCD4010 40 in. Television
How to use 1800 HG on a non BT IP
i got all green lights on my route and was working a week ago but for some reason it has stop work. please help
Jan 27, 2008 | 2wire 1800HG Router (RG1800HG00)
Cisco 7912G IP Phone Logo
4,536 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
