Question about Sony TA-E9000ES Amplifier
Power on but no led display
I noticed the protect display was on several times and now the power goes through but no display appears.
"Power board:
The power supply is the main culprit for most of the TA-E9000ES failures. Symptoms of this are no sound and a very dim or no display. Apparently the power board has several weaknesses which have caused Sony to supply a modified version in later production units. The circuit around transistors Q108 and Q109 are prone to oscillation, which will cause one or both transistors to break down, as well as resistor R124. This resistor is originally a surface mounted device capable of 1/10 watts of heat dissipation. The modification suggested by Sony is to replace this 4.7 k ohm resistor with a 1 watt rated version. Also, to prevent further oscillations a 100 pF capacitor is added in parallell with R153. (Some suggests that also transistor Q110 is a candidate for replacement.) The US issued service bulletin from Sony suggest that this fault may occur with units having a serial number in the range 800001 - 802746.
Serial numbers 80#### are for the US/Canadian version.
Serial numbers 50#### are for the european version."
http://home.online.no/~espen-b/ta-e9000es/#faults
Posted on Sep 10, 2008
  • 3 Answers
I have a 9000 es with the same problem. R124 was in fact burnt. i will replace it with 1 watt resistor and put the 100pf cap across R153, but what type - ceramic/electrolytic etc and what voltage cap is needed. Also do we need to replace Q108, 109 and 110 if they are not bad ?
Posted on Oct 03, 2015
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
Every time I unplug my Panasonic or the power goes out my tv won't turn on for a couple days. Then it'll work till we unplug it again or the power goes out again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Televison & Video
Two times red led blink error
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Aug 20, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
Jun 23, 2011 | Sony KV-XR29M61 TV
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
Mar 28, 2011 | Sony Televison & Video
Pc not starting from pressing power on. Green LED for SB_PWR is on and when power switch pressed, fan & cool fan flicker momentarily but nothing happens. They do not spin. No LED light appears on front...
> PC had been suddenly powering off several times intermittently for a few days leading up to this state. Does this mean the PSU or Motherboard is at fault?
Yes, either CPU or PSU or motherboard are the likeliest culprits.
It's easier to try a different PSU than to try a different CPU or motherboard.
Nov 18, 2010 | ASUS K8N-E Motherboard
JVC AV-K21T: TV goes off by itself
U know how to solder right?Take the backcover off take back of the handle screw driver taps where the part said it flickker or video back on, resolder that.
Sep 27, 2009 | JVC AV-20D303 20" TV
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Dec 11, 2008 | ZT Group CISNET A7050 PC Desktop
19" Topsync CRT display is flickering
the motiter to pc cable is problem yaar you change it the problem is solved
Dec 06, 2008 | ZT Group CISNET A7050 PC Desktop
Sony TA-E9000ES Amplifier Logo
676 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
