Question about Olympus EVOLT E-300 Digital Camera
BCM-2 in foreign countries
Can I use the BCM-2 in foreign countries?
    Master:
  • 852 Answers
The charger can be operated within the range of 100V to 240V AC (50/60Hz). When using the charger abroad, you many need a plug adapter to convert the plug to fit the shape of the AC wall outlet. Please do not use a converter, it may cause the charger to malfunction.
Posted on Sep 04, 2005
SOURCE:
My 2006 chrysler town country doir ajar light stays on as well as interior lights when all doors are locked
Have you checked the pin switchs at the doors ? This function does run thru the BCM but is not a common failure so I cannot rule out a defective in the BCM
Mar 15, 2017 | 2006 Chrysler Town & Country
Where is the flasher unit?, for Isuzu 280
wow1: easter egg hunt 2, and worse. there is NONE.
why do that?
wow2 no year stated, now that is a challenge. I-280 (the I matters)
this is USA forum , so not telling what country you are in is a
FAILURE.
wow3, no country.
they sell these cars in Africa and in Australia, (2 random picks)
an guess what, they are not the same cars.
answering for USA spec,cars.....
DO the HAZARDS work?
are the 3 fuses good.? f34,28 and 37?
ill guess now.
Isuzu i-280 2006 USA.... wild guess... toss a coin....
did you scan the PCM /BCM first. to see if there are DTC errors?
on this car the BCM controls TURN SIG's
its not like a 1995 car. at all.
what the BCM does to drive those turns , ive not a clue.
Isuzu does not publish BCM internal drawings, its a secret.
The BCM gets a digital signal from the stalk switch.
then the BCM (if fuses not blow and still programmed right)
activates its high power driver (some cars have transistors here, so no funky old school relays to fail) and the driver turns on
and the blinker glows. with HAZ selected, they all flash. all 4 drivers. that is how it works, ,knowing all that helps diagnosis.
why not post symptoms first.??
turns , hazards? dead, weak, too fast , too slow, left dead, right only, front only, or all are dead, and haz dead.
see? or dim?
symptoms....... matter, as does any thing else on car acting ODD.
your isuzu works much like my Jeep JK and wifes WK jeep.
THE BCM runs all this.
the body computer.
Check fuses first.
then SCAN it,
if you dont scan it , you will fail. if fuses are good.
if the battery voltage is low, the BCM can malfunction.
each car made is unique in what dies first.
but for sure something, will fail in the BCM or PCM.
what fails, with low voltage is not important in this case.
the voltage matters.
we see the BCM act odd in ANY way, see book on things it runs.
we check battery voltage first, then fuses, then scan it.
the brain goes a bit nuts with below spec voltages, near 10v.
the FSM book, turn sig, troubleshooting page
never once says replace any relay or flasher.
zero. 13 steps and step 12 says replace BCM.
see?
what i did on my Jeeps is reverse engineer my BCM.
(we have a forum for that) (1/2 done)
and some are transistors and others are relays soldered on to the main BCM. we can replace ours.
when bad, easy. (spares are $$$$ very expensive...)
but jeeps are very active here, for this hacking...
Isuzu are dead here...USA. not many left and no hackers about.(weak to dead support here.)
Isuzu bugged out in USA (left the country on cars)
so no driving to ISUZU dealers and using their 10x smarter scan tool.
it can in fact command the lamps on 1 by 1, no touching the turn lever..
to prove BCM is bad. see?
Id sell it.... if in USA.
sure would.... get jeep.
Jun 14, 2015 | Isuzu Cars & Trucks
Where is the body control module 2002 buick rendezvous
the body control module is under the radio. the center console plastics must be removed and it is in a clamp like bracket behind the floor shifter. quite a bit has to be removed. keep in mind that gm locked the bcm so you cannot use a used or salvage bcm because only very high end tech 2 scanners might be able to get in to program it and without programming the windows wont go down and the radio wont work.
Jun 09, 2014 | 1999 Chrysler Town & Country
I want isuzu hombre 1999 bcm wiring dirgram and color code
rooting?
BCM, the body cont. module?
what country, cars are made by country and are wired by laws for their country. and what engine option.?
what dont work right? just a clue to get in right page, would help 100%
if in uSA>
alldata.com has this. log in and look, or tell more....
Apr 30, 2014 | 1999 Isuzu Hombre
Application of passport
This depends from which country you are from. The best thing to do here is to go to the nearest Foreign Affairs office or the department which caters passport applications for your country. You can also try to look into the internet and search for info on the Foreign Affairs website.
Jun 21, 2011 | Computers & Internet
My 2001 chrysler town and country is having electrical problems but my mechanic is having trouble figuring out what it is. First, there is a ticking sound, the headlights go on when my headlight knob is...
Sounds like a BCM - body control module (computer ) problem ! Do you know what that is ? Did your Mechanic check for DTC'S - diagnostic trouble codes ? The headlamp switch is a input to the BCM , the BCM is hooked to a serial data network ! The BCM sends a message on the data bus to the intelligent power module which turns on the headlamps . The same with the insturment cluster , has a processor inside . Could be a loose ground etc.... I would try another mechanic . One you knows about computer networking .
Jun 14, 2017 | 2001 Chrysler Town & Country
Where is the body control module located on a 1997 town & country
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the BCM.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the BCM to the junction block. Slide the BCM downward to disengage guide studs on jb from channels on BCM mounting bracket
Mar 23, 2009 | 1999 Chrysler Town & Country
Where is the Body Control Module located?
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the bcm.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the bcm to the jb. Slide the bcm downward to disengage guide studs on jb from channels on bcm mounting bracket
Remove bcm from jb.
Jan 02, 2009 | 1999 Chrysler Town & Country
1999 Town and Country: door ajart light stays on , and interior lights stays on when head lights are on, interior lights go out when the inst lights are shut off by rolling inst lights dimmer to off,...
Get a wiring diagram. Unplug connector from BCM and do a continuity check on each door at the BCM. That'll tell you whether it's a door switch, wiring or BCM problem
Oct 14, 2017 | 1999 Chrysler Town & Country
Olympus EVOLT E-300 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
