Question about Electronics - Others
Torque setting Table for m2.5 ,m3,m4,m5.... m10 screws (csk & pan head ) setrting in kgf / cm.
    Scholar:
  • 132 Answers
This can not be answered with accuracy----
You will need to identify
1: - What material are the screws made out of (Steel / Nylon etc...)
2: - What material are the screws going into (Could be softer or harder material)
Posted on Aug 26, 2008
Toyota 5afe head bolts torque
Toyota 4A/ 5A-FE Cylinder Head Torque:
(a) Apply a light coat of engine oil on the threads and under the heads of the cylinder head bolts.
(b) Install the plate washer to each cylinder head bolt.
(c) Install and uniformly tighten the ten cylinder head bolts in several passes in the sequence.
Torque: 60 N-m (610 kgf-cm, 44 ft-lbf)
HINT: Cylinder head bolts are in length of 90 mm
(3.54 in.) and 108 mm (4.25 in.). Install the 90 mm
(3.54 in.) bolts (A) in intake manifold side positions.
Install the 108 mm (4.25 in.) bolts (B) in exhaust
Mar 31, 2014 | 2003 Toyota Corolla
Torque specification
- Install the plate washer to each cylinder head
bolt.
- Using Torque wrench, install and uniformly tighten the ten
cylinder head bolts in several passes.
Jan 26, 2014 | 1993 Toyota Corolla
REPLACING CYLINDERHEAD-TORQU SPEXS NEEDED
For the 12 Pointed Head Bearing Cap Sub-Assembly Bolts
Start from center bolts and tighten in a clockwise rotation working out
Step 1 all bolts 22 Nm or 16 ft lb
Step 2 all bolts 44 Nm or 32 ft lb
Step 3 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Step 4 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Hexagon Head Bearing Cap Sub-Assembly Bolts
1ZZ-FE Engine 18.5 Nm (14 ft.lb)
2ZZ-GE Engine 18 Nm (13 ft.lb)
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of theconnecting rod cap bolts.
2. Install and alternately tighten the 2 connecting rod cap bolts in several passes. Torque: 1ZZ-FE: 20 Nm (204 kgf-cm, 15 ft. lbs.) 2ZZ-GE: 30 Nm (306 kgf-cm, 22 ft. lbs.) If any of the connecting rod cap bolts does not meet the torque specification, replace the connecting rod cap bolts.
3. Retighten the cap bolts by 90 more
4. Check that the crankshaft turns smoothly.
Sep 11, 2012 | Cars & Trucks
Where is the starter? and How do I replace it?
Hello! It's under the engine on the right side under a cover...See diagram below...Guru...saailer
  1. DISCONNECT BATTERY NEGATIVE TERMINAL
  2. REMOVE ENGINE UNDER COVER RH...
    1. REMOVE STARTER ASSEMBLY...
    (a)Disconnect the starter connector....(b)Open the terminal cover....(c)Remove the nut, then disconnect the starter wire...(d)Remove the 2 bolts, then remove the starter....
    1. INSTALL STARTER ASSEMBLY Torque: 37 Nm (378 kgf-cm, 27 ft-lbf) for bolt 9.8 Nm (100 kgf-cm, 7 ft-lbf) for nut...
    2. INSTALL ENGINE UNDER COVER RH...
    3. CONNECT BATTERY NEGATIVE TERMINAL Torque: 5.4 Nm (55 kgf-cm, 48 in-lbf)...
Jan 09, 2012 | 2004 Toyota Corolla
I had lost the screws to attach the stand i have a 42lg30 tv AND IM TRYNA FIND THE SIZE OF THE SCREWS I NEED SO I CAN GO BUY REPLACEMENT ONES
Those are metric screws. I forgot the exact size, but I think it is Pan-head M4 fine thread. You could buy sets of M3 thru M5, and one of them should fit. Return the wrong ones.
Aug 06, 2011 | Audio Players & Recorders
Need torque for a 2000 Toyota Celicia GT 1.8L
Crank Main caps Tightening Torque
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of the connecting rod cap bolts.
3. Retighten the cap bolts by 90° more
Mar 18, 2010 | 2000 Toyota Celica
Bolt torque for 2004 camshaft and crankshaft gear
if your installing your crankshaft the Torque: 27 N·m (275 kgf·cm, 20 ft·lbf). And for your camshaft the 25mm bolts [2] are 7.5 N·m (80 kgf·cm, 69 in.·lbf) and the rest are 16 N·m (160 kgf·cm, 12 ft·lbf)
Jun 27, 2009 | 2004 Toyota Sequoia
Need to find specks on cylingder head for 1996 toyota tercel
The cylinder head bolt torque is a 2 step process.
First: Torque all of the bolts to 45 Nm (450 Kgf-cm or 33 ft lbs.)
Replace any head bolt that will not torque to the above specs.
Second: after all ten bolts are torqued to the above specs, the head bolts are then "Torqued to Distance"...
Starting at the center bolts, retorque all ten bolts an additional 90 degrees.
Hope this helps, the graciousness of a FixYa rating would be greatly appreciated.
Jan 21, 2009 | 1996 Toyota Tercel
Torque settings
  1. Tighten the cylinder head bolts sequentially in three steps. NOTE: Perform each step twice. 1st step torque: 39 Nm (4.0 kgf-m, 29 ft. lbs.) 2nd step torque: 69 Nm (7.0 kgf-m, 51 ft. lbs.) 3rd step torque: 98.1 Nm (10.0 kgf-m, 72.3 ft. lbs.) Use a beam-type torque wrench. When using a preset-type torque wrench, be sure to tighten slowly and not to overtighten. If a bolt makes any noise while you are torquing it, loosen the bolt, and retighten it from the first step.
Aug 02, 2008 | 2004 Honda Odyssey
Electronics - Others Logo
180 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
