Question about Cnet Wireless-G CAR-854 Router (CAR854)
Saving port forwarding configuration
Hi, i changed my port forwarding configuration in a cnet car 854 router '(to get a high ID in emule) then I didn't find any command to save my changes.
once I turn off my router, I should restart every thing.
Help please.
To make the change permanent, click Tools and select System commands,
on the system commands click save all.
Posted on Jan 05, 2009
How will i do port forward settings ?
Your router model is CWR-854, I suppose.
Port forwarding instruction for your Cnet Wireless CNET CWR-854 Router can be found here. Choose the program for which you want the port to be forwarded or use the Default Guide.
Oct 25, 2009 | Cnet Wireless-G CAR-854 Router (CAR854)
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
Aloha
Kahuna
May 28, 2008 | Computers & Internet
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Kad network lo id
Did you change the default ports?
This can be tricky, but there are excellent instructions at:
www.portforward.com
Oct 13, 2007 | NetGear DG834G Router
No KAD network on emule lo id?
Did you change the standard ports?
This site has excellent instructions:
http://www.portforward.com/
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Cnet Wireless-G CAR-854 Router (CAR854) Logo
161 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
