Have a Philips Match line tv Model 32 FD 9944/015. Prod no AG 040217 1 110657 S FM 23 Have difficulty on powering up. screen will not work. Cannot carry out set up. Have no operating manual. Isit possible for manuel to be forwarded.
5 Suggested Answers
  • 1894 Answers
SOURCE: vertical green line on left side of screen rear projection tv
fuses may have blown out i think..
Posted on Dec 28, 2007
SOURCE: TV -Ferguson (Wide Screen) model no: W7023U. unable to operate either with remote control or manually.
Is it possible it has locked itself? It can be locked in 3 ways according to manual.
1. by pressing the remote's stand by key for more than 3 secs.
2. By programming an auto stop.
3. By putting it on stand by after programming a wake-up time.
Flashing "red on" indicates it is locked. It can only be turned on by the remote. Press any number key on the remote to unlock it.
Posted on Aug 31, 2008
Sparko1
  • 167 Answers
SOURCE: How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Posted on Jul 30, 2009
  • 37 Answers
SOURCE: Doesnt turn on and beeps, philips match line rear
i believe it takes a couple minutes for the pamp 2 warm up and the start
Posted on Aug 22, 2009
hmerchant110
  • 7191 Answers
SOURCE: (wanted) Owners manual for (philips
You can download and print the instruction manual in PDF format from the manufacturer's website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Aug 14, 2010
Philips 32 inch LCD has colored vertical lines when powered on.
this sounds like a screen fault to me
try grabbing both sides of the tv and giving it a twist
this will either give you more lines or make ur lines go away if this happens u need a new screen
May 15, 2012 | Philips 32PFL3505D 32 in LCD TV
(wanted) Owners manual for (philips Digital TV match line) (model no 28DW9625/05R) (PROD,NO:AG 230141 102223)
Aug 14, 2010 | Televison & Video
Code for RENAULT RADIOSAT 6010 7700433074 PHILIPS 22DC461/62E 902221461622 PA4,4*15W,RDS CD changer control FD1199282300460 model no:22DC461/62E prod no:FD1199282300460 code gravage 2300460
RENAULT RADIOSAT 6010 7700 433 074 PHILIPS 22DC461/62E 9022 214 61622 PA4,4*15W,RDS FD 09 98 41 2033067 MODEL NO:22DC461/62E PROD NO: FD 099841233067
May 14, 2009 | Electric Renault R26 Radio Control Car
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Electro Med Services...
