Problem where is the paging file and how do i change it?
    Scholar:
  • 81 Answers
Hi Juliet_34tx,
1) right click on "My Computer"
2) click on "Advance" tab
3) click on Performance settings
4) click on "Advance" tab
5) in the bottom (Virtual memory) box click on "Change" button.
6) click on the radio button for "Custom size" and make the adjustment.
Note: A good rule of thumb ;
Initial size = 1.5 times your primary memory.
Maximum size = about 3 times your primary memory.
or you can use what your system recommends.
Good luck
Posted on Sep 03, 2008
DELL 1135N WILL NOT SCAN MULTIPLE PAGES TO ONE FILE
When you are at the option to "scan to" and you change it to PDF, change the file name and it saves it as that one file. If you don't change the file name it does multiple sheets.
May 16, 2012 | Dell 1135n AllInOne Laser Printer
Do not know how to scan multiple pages on the HP 6110 all in one Office jet. Please advise, Thank you, Andres
Hi
Click right mouse on the scanner icon and then change the file setting of your scanned file. Change it to pdf file not jpeg to scan in multiple pages. Another is by changing pdf to jpeg using the printer itself. Use the LCD screen menu to navigate.
Another way if you can install ADOBE ACROBAT READER PRO SOFTWARE, you can scan with multiple pages. Regads
Jun 21, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Virtual Memory is low
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
1.
Open System in Control Panel.
2.
On the Advanced tab, under Performance, click Settings.
3.
On the Advanced tab, under Virtual memory, click Change.
4.
Under Drive [Volume Label], click the drive that contains the paging file you want to change.
5.
Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in theInitial size (MB) or Maximum size (MB) box, and then click Set.
If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note
Right Click on My computer then select properties OR
To open System, click Start, click Control Panel, click Performance and Maintenance, and then click System.
To have Windows choose the best paging file size, click System managed size.
For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
May 04, 2011 | Microsoft Windows XP Professional
I have a game called juiced and When i double click to play it it says ,,Juiced requires virtual memory to be enabled".Can somebody please help me to fix this error and play my game please?I have...
Manually manage computer memory loadTOCNode(3, 'moreinformation'); When your computer's physically installed random-access memory (RAM) is running low, Windows adds available memory by using a paging file, generally known as virtual memory, on the hard disk to simulate physical RAM. By default, the virtual memory paging file that is created during installation is 1.5 times the physical RAM on your computer. Therefore, a computer that has 1GB of installed RAM will have 1.5GB of virtual memory.
You can manually change the size of the paging file to make it larger or smaller. You can also optimize virtual memory use by dividing the file space between multiple drives and by removing allocated space from slow or heavily accessed drives. To optimize your virtual memory space, divide it among as many physical hard drives as possible. When you select drives, follow these guidelines:
  • Try to avoid having a paging file on the same drive as the system files, usually drive C.
  • Avoid putting a paging file on a fault-tolerant drive such as a mirrored volume or a RAID-5 volume. Paging files do not require fault tolerance, and some fault-tolerant computers experience slow data writes because they write data to multiple locations.
  • Do not put multiple paging files on different partitions on the same physical disk drive.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usage loadTOCNode(4, 'moreinformation'); You can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box.
You may refer to this link http://support.microsoft.com/kb/308417
Apr 18, 2011 | Intel Core 2 Quad Q8200 Computer System...
How do you save separate pages in one Word file/
Go to page set up to change margins. A page that is scanned may take up more or less pages due to the the size of font on the page. You can adjust this by highlighting then change the font size.
Nov 03, 2009 | HP Officejet 6500 Wireless All-in-One...
BizHub C250 Scanning only single page files
The HDD was not set.  In other words, the machine has to be told in the service menu that is has a HDD.  FYI, you have to reconfigure you scanning afterwards.
May 07, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Memory stick pro duo pc connection
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
