Question about Yamaha RX-V450 Receiver
Amp. doesn't turn on
Amplifier has no power . fuse is ok and not blown. try to check transformer. help me pls.
  • Anonymous Jan 11, 2009
    same problem here !!!
    any solution ???
    Problem Solver:
  • 3 Answers
22nf 630dc/300ac capacitor inside back left board, i found mine on top of this board, a magnifine glass will help to check the writing on capacitor, replaced mine, works as new, g.knight. uk. ( rs components.)
Posted on Oct 04, 2009
  • 2 more comments
  • jean louis BOIX
    jean louis BOIX Jul 02, 2011
    also same troubles
    i tried to fix with your support (22nf swap) ---> 100 % ok
    thank you for your support
    BR from southern france
    Jean louis
  • jean louis BOIX
    hi
    same troubles, i tried your fix process (22nf to swap)
    100% OK, many thanks for your support
    best regards from southern FRANCE
    jean louis
  • Harbans Singh Jan 30, 2013
    Hi, Thanks. I fixed my amp as well by replacing C405 that horrible 22nF cap. Harbans from New Zealand
  • John Schrijver Mar 15, 2013
    Hi, this fixed mine also. Thanks. John from the Netherlands.
Additional detail about my AUREX STEREO AMP MODEL SB 130. I have change the rexridiwe / power diode but to no avail. This same result. The fuse rated 3.15 blown up 2 times. I wonder will is the cul
A module or an amp is doing a short cicuit. It's time to check if all transistors are valid. Be careful, bipolar and FET transistors behave differently. It can help to compare one by one each transistor from the RIGHT and LEFT amps. Good luck.
Mar 07, 2014 | Audio Players & Recorders
My stagg amplifier doesn't power on anymore, just
Internal power transformer or rectifiers. Could also be main power transistors.
Apr 20, 2012 | Audio Players & Recorders
Hi, using my amp for a long period on new years eve and the amp suddenly died. I've changed the plug fuse and checked internal glass fuse, both ok.Cant see anything obvious I.e. burning or over heating...
There's only one way to check the transformer and that's with a voltmeter. If there is mains going in but nothing coming out of the secondary, then that fuse has gone. They are not designed to be replaced and Transformers are what the trade call 'Safety Parts'. So they have to be replaced with the same thing. I would contact Teac and find out if they still do make them or where you can get one from.
Jan 02, 2011 | Teac A-H300 Amplifier
My amp is not getting power
Check the primary fuse on the positive amp wire usually located near the + battery2_bing.gif post. Also check any onboard fuses. If these check OK, make sure the remote lead has 12V+ on it when the head unit is turned on. If these all check out, the amp is most likely defective.
May 16, 2010 | Orion 1200D Car Audio Amplifier
Have Power going to the amp. Amp does not turn on. Do i need a remote? Bought vehicle with amp in it. LXA 600 Power light does not turn on.
you need to make sure you have 5 things.
1. power connection to the battery/amp
2. make sure you have a remote line radio/amp
3. make sure you have rca's radio/amp
4. make sure you have a ground amp/car frame ( scratch paint away for good contact)
5. make sure the speakers are connected to the radio.
if all is ok then check the inline fuse from the hot wire from the battery is not blown and the fuse on the amp is not blown.if so replace them. with the proper amp fuse.
Mar 24, 2010 | Jensen LXA400 Car Audio Amplifier
Amplifier lack of power supply
there is short circuit check the transformer and big capasitor for tanrsformer
Mar 21, 2009 | Jl Audio E1200 Car Audio Amplifier
Need a new transformer for an old kenwood stereo intergrated amplifier ax-31 cant find out where to get 1
let me give you a tip ;) power transformer has thermal fuse inside its tape-bounding area. try to locate it and check..transformer might be Ok and fuse has blown.
Aug 13, 2008 | Kenwood Audio Players & Recorders
Low sound on high gain no low gain new tubs
Your power transformer should not be getting hot. The signal is not passing to or through the output transformer.Check the speaker connections on the speaker side of the output transformer. Go to geofex.com and check the tube amp debug page.
Apr 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
Yamaha RX-V450 Receiver Logo
690 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
