HP Mini 1000 XP Notebook Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sir, i have hp mini 210-1000 laptop without cd/dvd. while installing windows xp i have deleted the partitions & tried to install xp from usb but failed. please help me to install windows xp .
Anonymous
Level 3:
  • HP Master 32,281 Answers
  • Posted on Jul 10, 2011
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7907805
Points
102259
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick.
The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed.
Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
1helpful
FORGOT USER PASSWORD HP MINI 1104
As an individual Windows password recovery tool, we just need 3 steps to reset lost HP password.
Step1: Download Windows Password Recovery Enterprise and install on any available PC.
Step2: Burn HP password reset CD/DVD or USB to reset lost Windows password.
Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive.
Step4. Reset lost HP password to Re123456 together with the burned CD/DVD or USB Flash Drive.
Not only HP password reset, Windows Password Recovery Enterprise can also be used to recover domain password on Windows server 2008/2003/2000 and local password for Windows XP/Vista/NT etc.
I tried to install windows vista on my hp 210-1041nr which already has ubuntu installed but i couldn't format the hard drive or even create a partition. It lept telling me that the hard drive has been...
To delete a partition using the Windows Vista DVD proceed as follows:
1 Switch on your PC.
2 Quickly insert the Vista DVD into your CD DVD-ROM drive.
3 A message will appear asking you to Press any key to boot from CD DVD.
4 Press any key.
5 A black screen will now appear with a progress bar along the bottom. The legend say's Windows is loading files.
6 After the files have been loaded the Language screen will appear.
7 Select your language from the list and press Next.
8 At the Installation screen press the Install Now button.
9 The product key window will now open.
10 Type your product key number into the available box and then press OK.
11 The End user Licence Agreement now appears. You must accept this to continue.
12 The next screen to appear is Where do you want to install Windows.
13 At the bottom of this window you will see an option marked Drive options (Advanced), click on this option.
14 In this Window select the partition you wish to Delete from the list available and then click the Delete option link.
15 A message will now appear informing you that the partition is about to be permanently deleted. Click OK to proceed.
16 Your Partition will now be deleted.
1helpful
Start up menu.
in SAFE MODE try to connect an external drive or usb flash and copy paste data from your computer to your external device.
If you have more partition on your hard like C, D , E..try to copy from boot device c: to another partition (like D:).
Installing windows xp
You will have to purchase an external dvd rom drive. Then select the external to boot from in system bios. You can copy win cd to usb stick and install from that but it is a little tricky. Good Luck.
2helpful
2answers
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
HP 520
See if you can F-11 into your restoration partition.
If not you have already deleted the main and secondary partition, all is lost.
Remove the drive and hook it up to another PC and see if you can review it.
If not start from scratch
2answers
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Trouble installing xp on a hp pavilion t3000
use the Windows Xp CD to format the hhd twice.
install the OS from the CD without partition.
you can always partition the hhd later.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
