Question about Olympus EVOLT E-300 Digital Camera
Media cards
What kind of media cards can I use in the EVOLT E-300 camera?
    Master:
  • 852 Answers
You can use Compact Flash cards (Type I and II) and Microdrive. By connecting with the CF Card adapter (MACF-10), xD-Picture Cards can also be used. Basically, you can use any manufacturer's Compact Flash Card in EVOLT E-300. The following Microdrive cards are verified as compatible with the E-300 camera: DSCM Series - DSCM-10340, DSCM-10512, DSCM-11000 3K4 Series - HMS360402D5CF00, HMS360404D5CF00
Posted on Sep 04, 2005
SOURCE:
My evolt e300 says the memory card is full,i have to pictures on it at all.
Hello :
You need to format the memory card to correct the problem .
please rate .
good luck .
Apr 08, 2010 | Olympus EVOLT E-300 (Double Lens Kit)...
Media Card Door Broke
Some battery doors and other parts are available on Ebay.
If this is the right link...
Ebay list of doors for this camera.
Sep 01, 2009 | Olympus EVOLT E-300 Digital Camera
Can't get the media card to fit flush in slot
Are you sure you have the right media card - and that you are inserting it the right way? Check the manual for the card type. Check that the card isn't damaged in any way, bent, etc. When the media card goes in it should go almost to flush with the top, but not quite. Does it work? If it does then no problem.
Jun 12, 2009 | Olympus EVOLT E-500 Digital Camera
LCD montior not on to see picture before taking picture
On the EVOLT E-300 it is not a camera that has a live view LCD screen that will allow you to see the image before it is taken. You must take the image with viewfinder only and only use the LCD screen for review purposes. This is how the camera was designed.
Mar 15, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Card error with both cf and xd cards
check the pins in your cf slot.. you may have one bent. either straighten it out or send to repair
Sep 28, 2008 | Olympus EVOLT E-500 Digital Camera
Transfering from smart media card to cd
The simplest would be to read the contents of the media card/camera connected through the USB port of a PC and burn it on the PC's CD/DVD burner. Alternately, instead of the camera/USB/PC/CD burner, you can use a memory card reader for the memory card. Requirements would then be:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Olympus Camedia Stylus 300 Digital Camera
Image adjustment functions
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Built-in flash
EVOLT E-300 model has been developed to allow everyone to easily enjoy superior digital imaging performance with a consumer-oriented digital SLR camera.
Lenses
ZUIKO DIGITAL Four Thirds System lenses can be used with the EVOLT E-300.
Olympus EVOLT E-300 Digital Camera Logo
102 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
