Fisher and Paekel washer GW508K
Washer starts to fill and then stops then repeats over and over then alarms.Lights are as follows.Far left green long wash light on.orange rinse light on.red spin light on
  • dicknisha Feb 19, 2009
    starts to fill then stops ,you can hear the soilenoid opening and closing realy fast ,tried it on the hot tap does the same .What controlls the water level ?
  • 1294 Answers
SOURCE: fisher & Paykel Smart Drive 9 Pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 13, 2008
juliankov
  • 13 Answers
SOURCE: F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Posted on May 04, 2008
beltronic205
  • 1474 Answers
SOURCE: The washer wont drain
Check clear filter //pump
Posted on Sep 29, 2009
  • 41 Answers
SOURCE: MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Posted on Jan 31, 2010
  • 713 Answers
SOURCE: I have a Fisher & Paykel GW608U
Hi just read your posting.Now the error code you have is error code 132,this means you have a single current trip error.This means the wiring to the motor and rotor position senor are faulty or one of the 3 phases on the motor is open circuit, or your motor controller is faulty. Do you have, or can borrow an electrical test meter ?To find the exact cause I can guide you throe the steps to test the machine if you have a test meter.Please reply for further help.
Posted on Jun 16, 2010
My fisher and paykel gw708u is intermitantly filling then goes into alarm and stops
Your rotor position sensor could be faulty,
your error code should be on the wash cycle progress lights.
Nov 18, 2012 | Fisher and Paykel Fisher & Paykel Washer
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
MY GW709 STOPS DURING FILLING UP WITH WATER AND IF YOU PRESS THE SPIN BUTTON IT WILL SPIN AND STOP FOLLOWED BY AN ALARM
Hi Benjimin,just read your posting.Now when the machine stops and beeps it will light up a series of lights.These lights will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 2nd and 4th or the 3rd and 7th ----etc----?Please reply with additional information and I am sure I can help you.
Aug 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Smartdrive 708
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
Oct 07, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
