Question about LG Washing Machines
My washing machine is not draining the water properly,so when i do a wash, the clothes inside after its finished are still soaking wet and then i have to manually drain the water from the clothes. I have removed the hose and found no blockages or kinks in the hose, so i dont know if it could be the water pump! what do you think. the washing machine is a fuzzy logic 6.5 model number wf-t655th.
    Master:
  • 497 Answers
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
  • Thanks for using Fixya!
    Posted on Aug 26, 2008
    Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
    2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
    Jun 09, 2016 | Kenmore Washing Machines
    Beko washing machine not draining
    If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
    May 21, 2012 | Beko WM5140W
    Wont drain water Gorenje WA61111
    locate the filter and clean, this should cure
    Dec 16, 2009 | Asko W600
    Clothes as still wet when it is finish after washing is done
    Hello Sassylips,
    Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
    Regards
    Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
    My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
    Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
    Sep 16, 2009 | Washing Machines
    I have run the machine on a daily wash
    It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
    Nov 20, 2008 | Indesit W 123 Front Load Washer
    When cyle is finish clothes are still soaking wet
    Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
    Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
    Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
    sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
    Feb 16, 2008 | GE WSXH208A Front Load Washer
    Washing machine
    check for blockage in the pump/drainage system. The drain hose has height specifications that should be followed, incorrect drainage may cause the water to build pressure and not evacuate properly.
    Jan 31, 2008 | Washing Machines
    Not draining
    it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
    Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
    Washing Machines Logo
    138 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
