Question about Acer Aspire 5500 5570-2609 Laptop
Restore factory settings for aspire 5570
I need help my laptop wont run setup for some reason all that loads is the acer screen and i need an answer urgently how can i restore my factory settings
  • 306 Answers
Assuming that you know how to normally access Setup then the surefire way to get there is to remove the RTC battery and then reconnect. Some laptops have NVRAM (non-volatile RAM) which precludes that and then you must discover the factory service procedure which is sometimes a dongle and sometimes a small boot program. Laptops are special and theft is always considered by the designers.
Posted on Oct 14, 2008
Acer aspire one restore failed: wont start now
the reason its saying,,ntldr is missing is because its lost somthing from the hard drive that it needs to run,it would have lost that when it stopd loading your windows.try it again and if it gives windows ,,,then do that.and it should do it because it should fint the missing file that it needs to carry on loading.
May 04, 2014 | Acer Aspire One Netbook 8.9" Notebook
How to configuration hard drive to factory default
Step 1:
Which operating system ?
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Mar 16, 2013 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire one d257-1417 trys 2 setup service but cant sumthing happen 2 microsoftwindows how can i recover without a cd
I'm not sure what you are referring to ?
If you do a factory restore and its a hardware issue the problem will still remain
You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 02, 2013 | Acer Aspire One PC Notebook
I need to reset my acer aspire 5520 to factory settings without recovery discs
There is a recovery console on your HDD (Hard Disk Drive) this is a hidden partition on your HDD. If you power on your laptop and hold the ALT key and keep tapping the F10 key while it posts to the acer logo screen it will goto a black screen with a flashing cursor on the top left then stop tapping F10 and remove your finger from the ALT key, you will then see windows loading files. This will take you to the recovery console and from there you can select restore laptop to factory defaults or restore laptop retaining user data.
Hope this helps
Feb 22, 2011 | Acer Aspire 5500 5570-2609 Laptop
Do not have recovery cd but want to restore factory settings.
you need to open erecovery and do a factory default restore ,and you wont need the disk for the recovery function either,thats as long as you have erecovery installed on your machine already
Apr 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Replacing the damaged hard disk and restore factory default
You need to load the OS, either its XP or Vista, which ever you prefer and then install all the drivers. Do you have a OS CD.
Feb 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop froze
You need a system restore disk
You can find it on the acer website
Nov 29, 2008 | Acer Aspire 5500 5570-2609 Laptop
Try re install windows and then go to and you can find all the drivers there.
Sep 18, 2008 | Acer Aspire 5570-2758 Notebook
Acer Aspire 5500
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Nov 06, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
