Question about Panasonic SV-AS10 Digital Camera
Panasonic SD card
Has anyone tried SanDisk's "ultra" or other performance versions? Any reason why the Panasonic is so much faster?
    New Friend:
Qu?t tr?n Panasonic s? l? m?t trong nh?ng s?n ph?m kh?ng th? thi?u ???c trong m?a h? n?m nay. M?i s?n ph?m c?a ch?ng t?i ??u th? hi?n ???c phong c?ch s?ng ti?n nghi c?a ng??i s? d?ng v? th?n thi?n v?i m?i tr??ng th?ng qua c?c s?n ph?m m?i.
Qut trn Panasonic
Posted on Apr 03, 2016
    Master:
  • 903 Answers
According to the specs listed at TigerDirect under different cards - including Lexar's 32x, 256 MB SD cards have a WRITE speed of 8X (Faster than 1.2MB/sec) and a READ speed of up to 10 MB/sec.
Posted on Sep 04, 2005
    Master:
  • 903 Answers
Panasonic SD Roadmap. Shows you the capacities and speed. 10mb/s is with 256 and 512mb cards. This should clear up some speed doubts with Panasonic.
    Master:
  • 903 Answers
've gotten the same results with my Panasonic 256MB, SanDisk Ultra II 256MB, and SanDisk 256MB standard (also since returned to Costco). The information Panasonic (and SanDisk !) put out on their websites led me to believe that the smaller capacity cards were 2MB/sec, and the larger ones, which begin at 256MB, were 10MB/sec. Those websites indicated that those speeds were the ones specified by the standards for Secure Digital Cards. Three companies developed that standard, and two of them were Panasonic and SanDisk. It came as quite a surprise to find that the measured read speeds of the cards on my USB 2.0 pathway were: Panasonic 256MB: 6.6-7 MB/sec Panasonic 16MB: 3.5MB/sec SanDisk 256MB Ultra: 6.6-7 MB/sec SanDisk 256MB normal: 1.4 MB/sec Maybe Panasonic didn't label their 256MB cards as "high speed" because all 256MB cards are supposed to be that fast.
    Master:
  • 903 Answers
I've got a 256 mb Sandisk UltraII. Most speed tests rate it very close to the high end Panasonic. Most of my 2304/low compression 5 shot bursts seem to write in less than 2 seconds, great for action sequences. It also uls via usb2.0 sandisk reader at a decent speed, much faster than the xDs I've seen on a usb1.1 port. The Panasonic 16mb that comes with the camera seems to be MUCH slower, I think it's actually a low speed, about equivalent to the low end Sandisk. It would be nice if Panasonic rated their cards....I think most of their bigger ones are all 10mbps anyways, but it would still be nice.
    Master:
  • 903 Answers
> The Panasonic 256MB SD card is twice as fast as the cheap SanDisk > 256MB I bought from Costco for $65. Saving the 5-shot burst at > 4MP, the Panasonic card takes only 2-3 seconds to save, whereas the > SanDisk card takes 5-6 seconds. Although the SanDisk works just > fine in video mode - I was able to fill the card with video. The > extra speed is also very noticeable on the Panasonic SD through my > 8-in-1 SanDisk USB2 reader on WinXP copying the files to my hard > disk. > > Has anyone tried SanDisk's "ultra" or other performance versions? > Any reason why the Panasonic is so much faster? the panasonic SD is rated at 10Mb/sec. ditto for the Sandisk Ultra II. I've got both versions of the Sandisk. the regular Sandisk is only rated at 2 Mb/sec which explains the slow save speed. the Sandisk Ultra II is much faster compared to the regular Sandisk.
How do i recover my deleted photos from my sd card?
There are numerous software utilities that do that. SandDisk has their own as well. Go to:
http://www.easeus.com/data-recovery/data-recovery-software/free-sandisk-recovery-software.htm
Oct 06, 2014 | SanDisk Ultra SDHC 32GB High Performance...
What program do I need to download my photos from my Sandisk Ultra 16gb SDHC Card
Is your card reader compatible with SDHC cards? While the card will fit into an SD-compatible card reader, it will not work unless the card reader was designed to be SDHC-compatible as well.
Nov 15, 2013 | Samsung SanDisk Ultra SDHC 16GB High...
What kind of memory card do I use
You may use any SD card up to 2GB in size (4GB if you can find any). Make sure you get an SD card and not an SDHC card, as the latter are electronically incompatible and will not work. The brand and speed won't make much difference, though a faster card may download faster to your computer if you use a compatible card reader. I'd also stick with the major brands, such as SanDisk, PNY, and Lexar.
Mar 01, 2013 | Polaroid T831 Digital Camera
Is Sandisk Ultra 8 GB SDHC card compatible with a Panasonic Lumix DMC-FZ30GN camera? When inserted in Camera error message check card flashes
No. The DMC-FZ30 was designed to work with SD cards. While SDHC cards will fit into the slot, they do not work. You'll have to use SD cards, 2GB and smaller.
Jul 06, 2010 | SanDisk Cameras
Is this camera compatible with a sandisk sd card?
Although most digital cameras will accept the correct version SanDisk card, without the make and model of your camera no one can give you an absolute correct answer. SanDisk, in my opinion, is the best memory card maker in the business. I use SanDisk SDHC crds and SanDisk Compact Flash cards in my cameras. I usually use at least the Ultra II models for the DSLRs.
Mar 02, 2010 | Cameras
What type of SD card does the digital camcorder recommend? Will a 2GB DC card work?
You need a faster SD card for camcorders usually - checkout Sandisk Ultra II series. or Sandisk Extreme III
Dec 23, 2009 | Jazz DV-179 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Speciel SD for e330
As far as I know the reading speed is always the same. I don’t believe that some other cards will be much faster read.
Sep 11, 2005 | Toshiba e330 Pocket PC
SD card for *ist DL
Interesting... I've heard that (for the DS at least) the camera isn't capable of using more than about 60X, but of course your downloads can be faster if you use a reader. At 2gb, this might give you some benefit, but a full transfer of 1gb on a garden variety sandisk only takes a few minutes.
Sep 08, 2005 | Pentax *ist DL Digital Camera
SD Card
They have not had a good reputation for reliability here, you might want to do a search on SanDisk. The consenses on SD cards seems to be Panasonc, SimpleTech & Lexar (32x best), in that order. Some (Pixy) have had good luck with th Ultra II, but several others have had SanDisks of all kinds fail.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic SV-AS10 Digital Camera Logo
199 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
