Question about NEC Dterm DTP 16D-1 Corded Phone
NEC 16C Telephone
How do I get another phone to ring after so many rings on the main phone
    Problem Solver:
  • 7 Answers
That would be a call forward no answer case. Ususally this is setup for forwarding you phone to voice mail. Same goes for if you want to ring another phone. Do you know your system access codes? Usually it starts with a * then follows by a number. Good Luck. Jerry
Posted on Nov 28, 2008
Main phone for office is not ringing, console will not ring. Just blinks. If portable phone is detached, portable phone will ring. But when connected to console there is no ringing.
if the phone was programmed to ring originally on the system try pressing the volume up key a few times while you know there is an incoming call on that phone
Oct 14, 2014 | NEC Lands Phones
NEC DTU 16D 1A not ringing
Your PABX line settings need to be programmed for "ringing" as incoming call notification for each specific assigned number (wired port assignment).
Jun 08, 2012 | NEC DTU-16D-1 Display Telephone
Phone not ringing
Seems a problem of signal interference. If all the 4-phones are made by the same manufacturer, then it is a sure case for this interference. You could solve the problem simply by getting another brand of phone, Sony, for example.
Aug 19, 2009 | Dmm Telephone Signaler
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
Additional User Stations not Ringing
You would need to determine which NEC phone system you have and obtain a programming manual for the phone system. Your phone could be used on different NEC phone systems that program differently. Phones only have user guides that explain how to use the features.
You can set up your system with Night Ring and have different ringing rules when the system is put in night ring mode. It sounds like this is what you are looking for.
Nov 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Delayed ringing time
Guillermo, to make an additional phone ring you must enter system programming. This is somewhat complicated, but I would be happy to step you through the programming over the phone. You may call me @ 850.326.0394 Phone Guy
May 24, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
140 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
