Phillips 32" LCD TV, Sound through TV speakers has a buzzing noise which is steadily getting more aNNOYING AND LOUDER.
We are having the "buzz" problem with our new 42' Phillips LCD too.
We do not have a sound system yet...but have read they have the same problem, so I won't assume when I get a sound system it will go away. What I did do for now...and it helped..
Go to the SOUND portion of TV menu
Turn down the two FAR RIGHT columns, they are the treble. It helped us.
Posted on Feb 25, 2010
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Have a 32" Toshiba LCD TV with no sound
go into menu look for sound click inside speakers or try to use outside speakers. i fixed 3 or 4 witk same trouble... good luck & happy 4th
Jul 03, 2009 | Toshiba REGZA 32RV530U LCD TV
Rca l26wd14 buzzing
I have seen this before in a lcd tv I worked on! My problem was some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). But also check the signal board (rca s-video etc... inputs). My thought in this was a bad cap was producing a harmonic, causing the speakers to squeal! Good luck, I hope this is helpful!
Mar 02, 2009 | Samsung LN32A540 32 in. LCD HDTV
High pitched noise
look where the power cable goes into the tv and see if the sound is coming from near there?
Aug 09, 2008 | Philips LM1200 PHILLIPS 12" 2GB OPTICAL...
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
High pitch sound from the speakers
Is the noise present even when there is no input?
Jan 27, 2008 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
