Question about HP ScanJet 2400 Flatbed Scanner
Yellow band in scanned image
When i scan i get part of the scan image with yellow band . band thickness and placement is random
  • Anonymous Aug 27, 2008
    I have the same problem and couldn't scan images in full-color.
    The "band" which also appears in grayscale scan previews doesn't affect grayscale scans, although what used to be mildly white in the previews are now solid black.
I solved bit by shaking the scanner like crazy
Posted on Sep 20, 2008
Umax powerlook - Scanned Image Light Bands
The scan optics are dirty or elements in the scan sensor have gone bad.
Jul 21, 2017 | Umax PowerLook 3000 Pro Flatbed Scanner
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
When scanning or copying on the 7310 on my Mac osX 4.11 the scans and copies have large black horizontal bands across the page. The band is randomly places and. If the scan image is good, the saved PDF...
sounds as if your scanner bulb is fualty I would suggest doing a power cycle - by removing the power cord while on wait ten seconds and plug cord back in or try a different power socket (preferbly a direct socket without any adapters connected to it)
Jan 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Thick black and grey line when scanning or copying a document.
Burn the thing it's junk. Go buy a commercial machine if you want something that works.
Apr 15, 2017 | Epson Stylus Multifunction Inkjet Printer/...
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
When printed from a scanned image vertical bands appear
Well, now, jannyloubran,
I hope that I understand your question: are you saying that there are vertical bands when an image is scanned, and then printed? In other words, if you download, say, a picture from your digital camera and print it, no bands: but, if you scan a photograph, then print the scanned image, you get the bands?
Going on that assumption, I would guess one of two things is happening, and possibly both:
  1. The resolution (usually "dpi" in America) is set too low on your scanner to get a very good scan, and so the print is poor. To scan a picture, you really should set the resolution as high as your equipment will allow and your hard drive has space for (the higher the resolution, the more space the file created from the scan takes). Without getting too technical and getting into optical vs. interpolated resolutions, 1200 x 1200 is usually an adequate starting point that will give a decent image (hopefully sans bands) without taking up gigabytes of storage space per scanned photo. You need to open the scanning software that came with your printer and set the resolution higher. If you can't figure out how to do that, open the help file that came with it or go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800. From here, you can search their FAQ, ask a question from their knowledge base, send tech support an email, or get a phone number for support.
  2. If your scanner is an older one (you didn't specify), then it may be either worn out (unlikely) or simply not able to support a high-enough resolution for the quality we have come to expect.
Now, if it turns out that I have been having a bad dream and none of the above applies, please repost with more information as to exactly what you have to do to replicate the problem, including what, exactly, you mean by "bands" (black and white bands, bands of fuzzy focus, bands of off colors, wide bands, narrow bands, bands all the way from top to bottom or just halfway, or what?). Also, have you changed anything else between printing from the computer and trying to print the scanned image, such as new cartridges or aligning or cleaning the printhead? I know it's a pain to spell it all out, but sometimes that's the only way we geeks can figure out how to help—and, I hope this helps!
Ken
Feb 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Yellow band when coping & scanning
this is problem with your scanner it is good if you can get servicing of your all in one printer
Sep 22, 2007 | HP Photosmart 2610 All-In-One InkJet...
A920 scanner malfunction
There could be the hardware issue with the scanner.So contact the tech support incase the warranty is still there and you could getb a replacement
Oct 31, 2006 | Dell A920 InkJet Printer
HP ScanJet 2400 Flatbed Scanner Logo
603 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
