Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Dropped Ixus 50 in water...!
I recently dropped my 2 yr old Ixus 50 in water.  Now it seems to be working as normal, except for two crucial aspects...the display screen shows no image (although it shows computer text such as flash status, image number), and although it takes pictures, the pictures are black - just like the screen.
What I want to know is, is this fixable, or is it time for a new camera?
  • 129 Answers
Place your camera in a hot press, or where your boiler is, on shelf and it might dry out in a day or two, then try it again.
Posted on Oct 02, 2008
Dropped Canon PowerShot into salt water
You're not going to like my answer. Salt water is very corrosive. Once it gets into a camera, even if you allow the moisture to dry out, will continue to corrode the camera and lens elements. Repair shops will not even touch a camera that has been dropped in salt water.
Oct 24, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped it on carpet while it was on and now it won't do anything, dead
..same deal here, except it was a concrete floor and I was drunk. It landed right on a corner. Later, taking it apart nothing seems broken or bent, yet not even the green LED indicating power will come on. Best of luck
Jan 04, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon iXUS 750 approx 3 years old. Getting E18 message. Lens will not retract, unable to take photos. Camera not dropped.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 12, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens Error ixus 800 is
Aug 02, 2009 | Canon IXUS 80 IS Digital Camera
We dropped our canon ixus 50 digital camera and lens jammed
You didn't mention what exactly is the problem. But please review the posts on the following blog, as they cover the most likely problems to result from a dropped camera to include lens errors, shattered LCD's, and non-starting cameras:
http://camerarepair.blogspot.com
Feb 02, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
It may recover afeter drying. However, tap water is full of stuff thats not going to play nice. You are better off gettting a gallon of Distilled water. this is electrically non-conductive and leaves no residue when dried. take out the batts and flash memory and soak the thing for a few seconds. hopefully the tap water and drink have not fully dried and you may get some use back out of it. You need warm heat to dry it out, Place it near a heating vent, heater or other heat source. you can get it as hot as you stand to touch (they are good to about 120 degrees). and a fan for circulation may also help. keep drying for at least a day, even a sunlit spot indoors can help
If water entered the lens group or got on the sensor, you are not likely to be able to repair this camera. repair costs will likely exceed its replacement cost.
Good Luck
Jan 09, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Only black spots on screen I dropped it
It seems that the LCD screen is cracked. You can find replacement screens for CANON cameras here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ViewObjectID=649065
Dec 14, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Dropped in water
this happened to me for more then 3 seconds in water for the razor, turn off the phone, remove the battery and SIM card, let it sit in a dry place over night, and check again next day, it should be fully functional
Jan 01, 2008 | Motorola Mobility RAZR V3
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
