Question about HP iPAQ H5550 Pocket PC
Water Ingress Hi, my Ipaq 5550 has recently met one of my children and the outcome was some window cleaner has got under the screen. There is a drying patch of liquid (it seems to get smaller every day), but the touch screen will not respond, do i need to buy a replacement screen or can i get around this problem. I have hard booted the unit to try and reset it but no joy. Anyone have any ideas????? Thanks.
Place a piece of tape on the screen and lift gently to lift touch screen from pad and it should separate if dry.
Posted on Sep 19, 2008
2002 Jeep Grand key light on no gauges, truck shuts off
This seems to be a problem with the PCI data bus. Many times the problem is water ingress in the connector C200 on the bulkhead up in the passengers footwell. Remove the connector, clean/dry it very well and apply some dielectric grease on the pins before assembling it again. Ofcourse you will have to find out where the water ingress is coming from. Could be from a leaking window seal.
Jan 10, 2014 | 1997 Jeep Grand Cherokee
Philips Shaver Faulty
Replacement under warranty involves promising to remove the battery from the old shaver and disposing of the battery and the carcass in an environmentally safe way.
The shaver can be split apart after removing three torx screws and then prising the plastic parts apart against their clips. Be VERY careful when releasing the plastic clips inside because they are brittle and fragile.
On opening the cover containing the battery, motor and control circuitry the ingress of water was clear. The shaver is supposed to be wet and dry, has only been used dry but the exterior has been washed.
The water was displaced using WD40. The shaver operated normally straight away. If your shaver's motor starts with the button but stops again half a second later, the problem might be caused by water ingress.
Dec 16, 2013 | Philips Aquatouch At890 Wet And Dry...
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
Hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Jan 24, 2009 | HP iPAQ H5550 Pocket PC
HP Ipaq h1940 won't sync with Vista
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
WPA-PSK and AES
on my ipaq hx4700 , i'm only able to use wpa-psk tkip, no aes option. not sure if any difference on 5550.
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
PAQ 5550 and MMC 4.x (Plus)
so MMC cards are the older version of SD cards. Ipaqs support the fast SD cards and all sizes up to the max.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5550 Pocket PC Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
