Question about Canon PowerShot S70 Digital Camera
Lens do not come out
Good morning,
I need an advise.
Unfortunately, my camera has been dropped on the floor.I can watch the pictures on the screen,I can even download them,but when I push the cover,the lens does not come out.It seems that the camera does not get power.I could see the cover of the lens makes contact with the metal part where is the lace.I tried to dismantle this metal part,I unscrew the small screw, to take out the lens cover,but no chance.Can you advise me what to do?
Thanks ,
  • 2,071 Answers
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Posted on Aug 26, 2008
Message on camera screen reads: lens error, restart camera. I have charged the battery, removed and reinserted and same message returns. I am unable to view pictures taken or to take any pictures. ...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 11, 2011 | Canon PowerShot SD1000 Digital Camera
The camera Canon G 9 bought in late 2008, was dropped to the tile floor from about half-meter height. After that, no defects in functioning except the focus. The auto focus is not working properly, the...
Hi Pavel
Sorry but your camera needs to have the lens replaced. The drop onto the floor damaged it and the only way to fix it is to replace it. Wish I had better news for you.
Thomas Drayton
Affordable Digital Camera Repair
Jun 10, 2011 | Canon PowerShot G9 Digital Camera
Dropped camera while it was turned on - now "lens error" appears on screen & can't turn off camera or view pictures
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 25, 2010 | Nikon COOLPIX L20 Digital Camera
Our camera was dropped this morning--now it reads Lens Error
oh no! you need to get the camera checked. there might be a lens that got dislocated inside the camera. Nikon is pretty fragile. Get it fixed asap or moist will damage the lens and it won't work anymore.
Sep 03, 2009 | Nikon COOLPIX S10 Digital Camera
Samsung s860 camera got dropped turns on but screen is only white
dropping the camera might have caused damage to your LCD screen, best advise I could give is to send it in for repair
check if you can still view old pictures or if the on screen displays are visible, it will narrow down if the problem is with the lens or the screen
hope this helps
Mar 30, 2009 | Samsung S860 Digital Camera
Only takes pictures when it wants to
It sounds to me as if this camera needs an urgent service. Most likely a connection inside has become intermittent. Unfortunately dropping a camera is one of the worst fates I could ever wish upon someone. We all know to use the strap, but we only drop them the instant we let go of the strap.  You were very lucky it did not land lens down. I have seen lens mounts ripped from their anchoring with the remainder of the lens smashing the mirror and sensor. At least it works temperamentally. Good luck with the service!
Dec 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Dropped my camera.
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 22, 2008 | Canon PowerShot A85 Digital Camera
I teach a children's gardening class. The children have a Coolpix camera for taking pictures of their gardens. Unfortunately a camera was dropped and will no longer work. It just says lens error when...
It sounds like the fall knocked the gearing or track of the lens off. The unit will need to be taken to a repair center to be put back on track.
Apr 17, 2008 | Cameras
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot S70 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
