Question about Hotpoint TDC32 Electric Dryer
Hotpoint CDT40P error message
My dryer got jammed, once un-jammed it all worked well except it stopped heating. I have replaced both high a low temp thermostats and now it is flashing an error message at me; the on/off light is flashing very quickly and the time delay, pre creasecare and alarm light are all flashing simultaneously at approx 1 second intervals. can you tell me what this error message means? thanks
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
WHOEVER DIAGNOSED THE PROBLEM DOES NOT HAVE ENOUGH EXPERIENCE!
YOU NEED TO USE FACTORY SERVICE !
OR IF IT IS 10 YEARS OLD OR MORE ,DO NOT WASTE MONEY FIXING IT! THE NEW ONES ARE MUCH MORE EFFICIENT!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
My matag dryer #mcg8000aww heats and then after a few minutes stops heating
you high / low temp thermostat is going bad need to replace it. or your vent is clogged and it is over heating. and shutting down to prevent a fire.
Aug 21, 2014 | Dryers
Whirlpool Dryer LET7848A - no HIGH heat
yes the coils which heat the heater heating plates are faulty because of broken wire.
they hshould be replaced to make it work.
thanks.
Sep 21, 2008 | Whirlpool Dryers
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Cotons high heat not working ctd80
one element could be broken , dryer takes two for high and only one for lower temps
Nov 26, 2013 | Hotpoint TDC32 Electric Dryer
My dryer heats but takes two cycles to dry clothes.
Check the hose in the back and vent to make sure it is breathing properly first. Most driers have a thermistor moisture sensor. Try replacing it first. It nether of these works your heat strip may be shorted so only heating partially. Most driers have two or three thermostats also. Two on the heater cover. One is the high temp and one is the low temp. Usually the high heat will be the problem (cuts out to early before the heat strip fully heats). Others have a third one on the exhaust blower. Check these at room temprature with an ohm meter. They should have continuity. If not replace. Thermostats that are open with no continuity will usually cause the heater not to heat at all. Thermostats can get old and stop working at their intended temp. Replace one at a time
Jan 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Tdc30 dryer
rthe high temp thermostat is located on the heater box,the low temp thermostat is located on the blower box ans the main fuse is the smaller round one-let me know how you do-mike
Oct 15, 2008 | Hotpoint TDC32 Electric Dryer
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
Dryer keeps cutting out
Dryer outlet hose could be plugged or restricted not letting adequate air cirulate. Check this and the filter to be sure both are clear of obstructions. Make sure the flapper at the end of the dryer vent is working correctly.... A blocked vent will cause the temp to get too high and the unit shuts down rather than burn down the house.
Jan 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint TDC32 Electric Dryer Logo
151 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
