Question about Ultra Linear UL-600HC Car Audio Amplifier
Ultra linear ul-600hc
Worked great and disconected speaker wires while playing and accidently touched them together now amp doesnt work pls help
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Posted on Aug 26, 2008
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
Amp was playing fine. Was unhooking speaker and accidently touched the remote bass plug on amp. One speaker was still plugged in and playing while this happened. Now when I hook up the speaker all I get...
Maybe, but you would need to take it to a stereo repair shop. If a wire is burned out or a small component is blown, it can potentially be replaced. May be cheap and easy, or may be too expensive to repair for the cost of the amp.
Mar 10, 2011 | Rockford Fosgate T15001BDCP Car Amp
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
IVA-D300 only LEFT speakers work.
try this get ur self a AA battery take ur stereo out of and get the two wires going to ur speakers that are not working and touch the battery with one wire on the positive and the other on the negative and see if u hear a poping from the speaker. and if u do thats the right wires and if u dont u need to find the right wires.( MAKE SURE UR STEREO IS NOT CONNECTED WHEN U R DOING THIS TEST. ALL SPEaKER WIRES NEED TO BE DISCONECTED WHEN PERFORMING TEST.)
and if u hear a pooping sound and it still dont work place the working speakers on the side thats not playing and if the dont play ur out puts are bad in the stereo and u need a new stereo. hope this helps
May 04, 2009 | Alpine IVA-D300 Car DVD Player
My ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Jan 07, 2009 | Car Audio & Video
I touched two speaker wires together and amp will not respond
That is a very nice amp . Try not to touch (short) those wires together. But yes, the amp has protection and is shutting off to protect it.
Nov 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Panasonic SA-HT05 Reciever wont turn on,the red lights on and it clicks when i turn it on but it doesnt work.
i had the same problem check if any of your speakers are disconnected mine i was doing some work to it and i let the wire accidently touch a peice of metal and it would play for a bit then just stop playing music it is something to do with it heating and such
Apr 23, 2008 | Audio Players & Recorders
Kicker amps not working
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 10, 2008 | Car Audio & Video
No sound coming out
I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Aug 07, 2007 | Jl Audio E2150 Car Audio Amplifier
Car sub not working
has your amp been accidently swiched to stereo instead of mono,if so,swich it back.
Nov 07, 2006 | JBL GT150 Car Subwoofer
Ultra Linear UL-600HC Car Audio Amplifier Logo
145 people viewed this question
Top Ultra Linear Car Audio & Video Experts
richie46
FastHarley
FastHarley
matthew nulph
Level 1 Expert
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
