While downloading some pictures from the camera it suddenly went dead and the lens did not close..it hasn't turn on since...i charged the battery but no luck at all...any help..
i got the same problem,it hasn't turn on since then, i guess the camera's dead and im pretty worried about the camera,do you think it's not junk yet?..
You can't post conmments that contain an email address.
Use a card reader to download the pictures instead. I never figured out how to use the cable that attaches the camera to the computer. I've been doing this for 4 years and haven't had a problem!
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
Using the wrong cable can certainly damage a camera.
You don't say what "inoperable" means. I have sold and serviced many digital camera over the years. Dropping a camera will often result in damage to the lens assembly causing blurry/distorted pictures or the lens will not extend or close.
If the camera is completely dead or fails to boot then you probably used the wrong cable or connected it incorrectly and fried the internal electronics. This particular Gateway/Samsung camera can be fried if you connect or disconnect the USB cable while the camera is power on.
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures.
The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera.
David Millier
Advance Camera Repair
