Question about Cameras
Memory card erreo message
Both cards give back a card error message. Cards are K.
When i try to make any action with my nokia N73 512MB micro memory card or format it it doesnot responde and i recive a message the disk i wreite protected
Posted on Dec 26, 2008
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
Won't read sd cards
If this happens with the second time, great chance it has nothing to do with the card(s). Your camera should be capable of handling all SD cards. So SD, SDHC and SDXC cards.
But perhaps something came in the memory card holder of your camera. Just a little piece of paper or dust? Please check if all the contacts in the camera are clean and shiny.
Then there is a warning in the manual, about the batteries you can use.
A list of batteries, if used can damage the memory card, because these batteries can't deliver enough power to make writing on a memory card reliable. The warning is on page 14 of the (English) manual. Only one type of battery can be used. Only Ni-MH rechargeable batteries should be used. Although the manual says Alkaline should go to, I have to advice against that. because they too can give less power, in certain situations (like in cold environments)
The memory cards that gave these error messages, should be checked in an external memory card reader on a computer. And when they are connected, please give them a format there (FAT32)
If you had the wrong batteries in the camera, after putting in fully charged NI-MH batteries, you could try to format the cards in the camera too.
Feb 03, 2014 | Panasonic Lumix DMC-LZ20
Memory card error
Make sure you're using SD cards. If the cards are larger than 2GB then they're actually SDHC cards. While they fit in the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Aug 05, 2012 | Pentax Optio MX Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Bought a memory card for my Kodak 'EasyShare' C530 and I don't know if it's the right one. I bought a 2GB Memory card with MMAGFQ2WDCA-D8 on the back of the card itself. The error message I get is...
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Kodak EasyShare C315 Digital Camera
Hello, my camerca is giving me a memory card error
You probably just need to format the card in the camera. This will erase it so download any pics first.
Mar 14, 2010 | Canon PowerShot S3 IS Digital Camera
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
May 11, 2009 | Nikon COOLPIX 5100 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Card lock
Dear geogie:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
Jun 09, 2008 | Samsung S630 Digital Camera
Cameras Logo
134 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
