Question about Lite On Computers & Internet
Not reading disc.cd/dvds - Lite On Computers & Internet
    Novelist:
  • 125 Answers
Solution 1.
Firstly lets see if your drive is working!
Put in a disk you know works and has files of some sort on it
If nothing is still happening , goto my computer and right click on your CD drive and
click "explore"
Do you now see files ?
If not right click on "My computer" and click manage
The "Computer Management" Console will now popup and you will see a selection of
headings on the left , click the plus (+) sign on "Storage" to expand it then click on
"Disk management (Local)
In here you will see all the storage devices attched to your computer , including your
Hard Drives , Floppy Drives , USB Flash Drives etc.. , from here you should see your CD
Drive , if you do and right click it and explore the drive and you do see files ,
change the drive letter of your CD-ROM drive from the default D: to say like F: or
something , right click the CD-Drive in the Disk management and click change driver
letter , and follow the instructions.
If you dont see the files or you dont see the CD-Drive at all do the following:
1. right click my computer
2. click on properties
3. a new window will popup
4. click on the hardware tab
5. click on device manager
the device manager console will now open ,
from within here find your CD/DVD Drive under the DVD/CDROM drive heading,
right click the appropriate drive and click on uninstall.
Now reboot your computer and then windows should detect your CD /ROM Drive and reinstall it , you may now again need to reboot in order for your CD Drive to function correctly If this doesn't fix your problem try upgrading the firmware of your Drive.
**im assuming your running Windows XP for that solution but i would think the process in Vista would be very similar.
If you have a spare computer that is unused maybe you could try it on that machine and see if it works , if it does a fresh installation of Windows on your current machine may be the solution as it could be infected with a virus which just may have corrupted the window drivers.
Solution 2.
If the DVD Drive is connected on the same ribbon cable as the Harddrive , the Hard Drive should be set to Master on the Jumper settings and the DVD Drive set To Slave otherwise if it's on a seperate cable it should be connected at the end of the cable and set to master. If you do / have done this can you see the devices in BIOS ?
Solution 3.
It sounds like some dust or hair has landed on the Laser Lens (The component responsible for reading the data on the CD) and is interfering with the playback , to clean this your self you will need a laser lens cleaning kit to safely remove the debris.If you're finding that after cleaning the disk the DVD is still skipping try cleaning the cd , as debris on the CD itself can also cause interference for the laser lens
Posted on Aug 26, 2008
Does it play cd and dvds
You can only play CDs of all kinds (CD +/- R, cdrw, etc.) but you will not be able to play any DVDs. It will not detect any DVD disc.
Jun 23, 2010 | LG CRD 8400B (CRD-8400) Internal 40x...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
Panasonic DMR-EZ75V reads ''NO DISC'' for DVDs
I had a problem w/my dmrez475 and called pan @ 1-800-211-7262 and talked to John at ext 5070.
He seemed very knowledgeable and sent me an update CD. The CD fixed my problem which was in
the timer recording mode. Call him, maybe he can help.
Jan 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Will not read DVD discs.
It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
A dirty lens can read CD but not DVD.
Tru first using a lens cleaner like this ones:
If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
You can order the lens pickup from factory and replace it.
Sep 02, 2008 | LG Computers & Internet
Not reading some dvds
Could be it does not like the brand of dvd discs, if they are dvd burnt discs. You need to be more specific, is it reading any dvds at all??? If it has no issues with cds, it may not be the driver, but if it is playing up, it would not hurt to try unistalling it and reinstalling also with an updated driver. good luck lilacgerry xxx
Jun 28, 2008 | NEC (OP-260-74503) CD-RW/DVD-ROM (Combo)...
Disc reading
hi there
long reading time for cds or dvds only means that there might be dust or residues hindering your cd lens to accurately read the data of the cd/dvd. what you can do is try to clean the lens with a cd cleaner.always check the cd/dvd that you insert are clean and fre of dust . if this still wont work and the player still have the long time to read the cd/dvds, my advise is to bring this to a service center and have this checked out.
hope this helps.
Feb 05, 2008 | Samsung HTQ45 System
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Computers & Internet Logo
326 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
