Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Front panel connection
i have asus motherboard , where can i connect the front panel usb .
thank u
  • Anonymous Dec 18, 2008
    manual Asus P4BGL-MX
  • 2,351 Answers
Hi mubarakdream, please open your manual to page 1-6, motherboard layout. Find USB20_5 & USB20_6 page 1-14, at the bottom of the motherboard. You can plug your front USB onto these USB pins. (Careful, front & side case USB's break very easily). It only takes a slight bump to break.
Leave the motherboard jumper set to default for USBPWR_56, page 1-10.
If you need the Asus manual you can download it from this link;
If you need more information just post back into here.
Good luck mubarakdream!
Posted on Aug 26, 2008
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
For additional questions please post in a Comment.
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
May 12, 2009 | ASUS Computers & Internet
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
Asus p5ld2 connect to front panel
The front panel connections are on the same side as the SATA connections about halfway down the board on the edge. They should be labled in small print. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | ASUS P5LD2-VM Motherboard
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Front panel connectors
hi im wesley. ok the power and audio connecters is very simple if you look at the bottom right of the motherboard you will see you can plud them and it says the name of witch is the power and witch is audio and it doesnt realy make a difference witch way you put them in just as long as they are on the right pins. the usb might be a little more tricky unless it says witch connecter is the usb 1&2 then its the same as the power led but if you dont come right i will try to get a diagram for you or draw one up but it might not be as accurate tho as i do not own a asus motherboard but i will do my best.
Jul 11, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
May 15, 2008 | ASUS P5PE-VM Motherboard
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
298 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
