Question about Soleus Heating & Cooling
The Plug on my Soleus Mac 12,000 Air Conditioner gets hot and it shuts off. The plug has been replaced once, what can solve this problem!
  • musikmakerLA Aug 27, 2008
    Hi Koolbreezes,
    Thank you very much for your help.  Well how do I clean the compressor?  Is it a do-it-yourselfer, or do I have to take it in? Where is the compressor on the unit?
    Thanks again for your input.
NO! Isaid the back coil are clogging up, not the compressor clogging up. The fan blades and a slinger ring picks up the water and slings it on the back coils and evaporates the dirt and calcium out the water and deposit them on the coils, which over time, builds up and closes the air flow through the coils which helps cools the hot gas, which sends the not -so -cool-gas back to the compressor which draws more amps due to higher temperatures the compressor working in ect..ect..ect.. (see where -I'm going with this? Thank-you-very-much!
Posted on Aug 27, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This mean the compressor is drawing too much amps, caused by the back cois are clogging up and not getting rid of enough heat.Hope you clean it soon before it ruin the compressor. Thank-you-very-much!
Posted on Aug 26, 2008
We cannot find our manual and cannot figure out how to hook up the air conditioner part of this item. Can you provide instructions?
I've uploaded a manual, which should appear on the site within a day, but can you provide more detail with your question? At a basic level, there's not much to do: Run the big air hose outside the room you want to cool, plug it in, turn it on. Drain the water bucket when the unit beeps and flashes its LEDs. That's about it.
Aug 01, 2011 | Soleus MAC-8000 Portable Air Conditioner
My exhaust hose has a tear. where can I get a replacement
You can find a substitute at any home center. In the Heating & AC Parts section of the store. Just be sure to get the same diameter and use the existing connectors off the old one.
Jul 13, 2011 | Soleus LX-120 Evaporative Portable Air...
How to keep the fan speed on low at all times on the Soleus Air MAC-10K? Every time we adjust it to low after about 10 minutes it automatically changes fan speed to high and it does not go back to low...
dear sir
i think your air conditioner,s micro controller system is not working well, that why this problem is coming .please contact to your product dealer for replace it .
hope answer the question
thank you
please vote!
Sep 29, 2010 | Soleus MAC-10K Air Conditioner
Blows hot air after 5 min. of startup
Check condensor coil for uniform heat all over the coils
If there are "hot spots" Then the condensor may be restricted inside
Check compressor heat. If its too hot to lay your hand on it then
You probably have a restricted condensor which shuts off the compressor with high head pressure
If the unit is old you may want to consider a replacement.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Soleus MAC-7500 Air Conditioner
How to empty water out of unit?
drainage plug is really away to the ground, so you may want to place it on a hard surface or elevate it slightly to assist in the drainage function. You do get a short hose and drip pan in the box to help you empty the moisture into a larger pan, but you may want to keep a towel convenient as well.
Aug 03, 2010 | Soleus MAC-10K Air Conditioner
Who has the parts for a Soleus Air MAC -12 portable A/C
If its the part that turns the louvers on the output the part number on the back of it is 24BYJ48A. Its a small stepper motor. Unfortunately I too need one and haven't yet found a supplier in the US.
Good luck
Ron
Jul 14, 2010 | Soleus LX-120 Air Conditioner
Soleus mac 12-k air conditioner runs for 45 mins then trips breaker. i reset and then 20 mins later shuts off again.
first of all an amp reading needs to be taken to see how many amps the AC is drawing. It may be too much for the breaker. Also see what else may be wired in on the same circuit, there may be additional load on the breaker. If all amp readings are below the rating for the breaker then you may have a faulty breaker, but that's pretty unlikely. The most probable cause is you are overloading the circuit.
Sep 14, 2009 | Soleus MAC-12K Air Conditioner
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
Cant get it to turn back on
The plug usually has a reset button on it and if it won't stay on there are a couple of things to check.
Check voltage and make sure one side is not tripped at the breaker or disconnected at either end.
Breaker could be bad.
Compressor could be bad or have a bad start switch assy.
srich
Jan 06, 2008 | Soleus MAC-10K Air Conditioner
Heating & Cooling Logo
361 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
