Question about Philips 55PP9352 55" Projection Television
No Picture No Sound other than chirping
Power is on, there is no picture, no sound comes from the unit only a chirping noise. The sound from the channel does come through the home theater system.
How do I fix it?
  • zaabubu Aug 26, 2008
    Thanks VOTIT, I am new to FIXYA.com and was trying to get a sense, with parts scarce, if it is worth it to fix, or should I buy a new TV.
  • 2,071 Answers
From description you provided that the red light is on or a stand by light and a chirping sound,chirping come from horizontal section maybe H-OUT transistor is busted. Look also the power supply section is in the P-BOARD which has the reading of test point =170v, P-board is a power supply board ,bad regulation of the incoming voltage could cause the issue and maybe there is a capacitor across the incoming line which dry up or leaky already and cause the problems ,change it out with one identical rating.
Also Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Posted on Aug 26, 2008
  • LORETO LACARON
    LORETO LACARON Aug 28, 2008
    Yes it is worth to fix,because only just little problem,if you go a TV shop,maybe they cost you $ 50 to $75...
    Hope this may help
    DON'T FORGET TO RATE;
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
No Sound or Picture, Chirping Noise coming from back
There are many other fuses on this board you need to check them all. May need a schematic.
Dec 03, 2007 | Philips 51PW9363 51" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
