Question about Dell Inspiron 6000 Notebook
I got the below error ... is it possible tot ake my backup from the HDD?
Device: Hard Drive,Test: Start DST Short Test, Status: Error Detected!
Error Code: 1000-0146
Test Result: Fail
Thanks
  • purplepelika Aug 28, 2008
    i have the same exact problem. my screens image looks like the "negative" from a film picture. any solutions?
    Genius:
  • 2,028 Answers
A 0146 error means that the hard drive has a failing sector, and the drive will need replaced. If it's operable, then back everything wanted or needed up, because it will fail completely if it hasn't already.
Posted on Aug 28, 2008
I am having issues with my laptop Dell Vostro 1510. Getting a black screen and white cursor in the upper left hand corner.
The error code indicates that the system is not able to access or detect any Hard Disk Drive.
If comfortable you can try the following:
1. Open your laptop following the below guide
2. Look for the Hard Disk Drive
3. Remove it from the system
4. Re-seat the Hard Disk drive
5. Re-start the system
If still the HDD is not detected I am afraid to say that the Drive is gone bad and needs a replacement.
Kindly feel free for any further clarification or assistance.
How to take apart Dell Vostro 1510 notebook
Sep 13, 2012 | Dell Vostro 1510 Laptop
Error 301 hard
Compaq laptop has detected a SMART fault. You should backup your data and test the harddrive with the maufactures diagnostics like Seatools for Seagate. Run a short DST. Drive may pass. I would still replace it. Clone your current drive to the new one. The drive is probably on its way out.
Aug 20, 2012 | Compaq Presario CQ61-310US Laptop
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I have a dell studio 1737 laptop i purchased in Feb of this year. my computer works for about 10-15 minutes then crashes completely. i went into safe mode and found that the consumer IR devices will not...
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Dec 05, 2009 | Dell Studio 1737 Laptop
Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
you might have jarred the memory loose. take it to a local technician to have them check it out.
Oct 10, 2009 | Dell Latitude D610 Notebook
DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Aug 16, 2009 | Dell Latitude D610 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
520 people viewed this question
Alun Cox
