Question about Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
  • Panasonic Master
  • 9,098 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 02, 2008
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
Panasonic over the range "genius" model door won't open. Is there lock on it?
No, there is no lock. The latch is jammed. This is a toughie. Breaking the door or latch seems wasteful. Can you return it? How did it get "stuck"? m
Nov 09, 2009 | Panasonic NN-SN657SMicrowave Oven
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Door will not latch
The door switch mechanism is broken. Microwave doors have a special arraingement of double switches to ensure it is not open during cooking. Because everything is made from plastic nowadays, stuff like this breaks easily. The switches are commona nd cheap but the mounting parts may not be.
Dec 28, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
531 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
