Question about Fisher Paykel EcoSmart GWL15
Fisher & Paykel GW712 cold water dont work???
The machine wont pump the cold water though it only works on hot water, can anyone help
  • Anonymous Mar 15, 2014
    cold water backflow
  • Anonymous Mar 28, 2014
    no hot water
  • 2,071 Answers
I have a Fisher & Paykel GW712 (approx 2003), will work up until the first orange rinse light. It does a small drain but then the 3rd, 6th & 8th lights come on (left to right) & it beeps continuously.
thats an error code for the drain pump, if it drains a bit of water then stops the drain pump is faulty (usually overheating coils from corrosion especially if you get a hot metal smell when it happens) dont keep doing it as it has tendency to blow the control board, you will need to replace the drain pump
Feb 04, 2017 | Fisher Washing Machines
Fisher @ Paykel GW 712 washing machine error code 49?
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
Jul 27, 2015 | Fisher Washing Machines
GW712 - cold wash selected but water runs warm. If hot water supply turned off, machine stops?
The cold water temp has been adjusted to a warmer temp,
Move the led back to the first led light with advance button.
Jul 01, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GW712 hot water fills fine - cold water just trickles. Was working fine until yesterday
Turn that spigot off, then unscrew the hose from the machine and inspect the screen that is there (on most machines, some have internal screens/filters) If that screen is clogged, you can clean it or get a new one, if it is damaged. Place the hose inside the washer, or someplace you know the water will drain away, turn on the spigot to make sure you have a flow from the spigot to the end of the hose. Reattach and charge the hose. I believe this will be the answer.
Hope it is helpful. Please rate and comment, Thank You
Joe
Sep 01, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
405 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
