Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
“Custom Button”
What is the “Custom Button” used for?
    Master:
  • 852 Answers
The custom button can be used to assign specific camera functions set by the user. This function allows the user to quickly select assigned camera functions by pressing the custom button and selecting settings using the control dial.
Posted on Sep 04, 2005
SOURCE:
My Samsung Se will not open. there is a message CUSTOM BINARY BLOCKED BY FRP
detailed solution:
https://drfone.wondershare.com/factory-reset-protection/solve-custom-binary-blocked.html
Nov 14, 2017 | Samsung Cell Phones
I have a z6100 designjet printer. I often print direct from Acrobat using the HPGL2 driver. The problem I have is: I rarely am given the option to delete the custom paper sizes that I have created. The...
just use your custom paper size and rewrite the settings.In some drivers U cannot delete the paper size from the driver properties.IF U still want to delete the custom paper size that you've created They are in the windows registry_but deleting keys from there is not recommended.
May 09, 2011 | HP Designjet Z6100 InkJet Printer
In custom setting, assigned the front function button to display framing grid. function button does not respond when pressed. am i missing something here? thanks
Aha! While pressing the fn button, turn the main command dial (the one on the back) to toggle the grid display.
Personally, I like having the grid, and used custom setting #D2 to turn it on the first day I had the D90. This frees the fn button for other, IMO more important things.
Mar 14, 2010 | Nikon D90 Digital Camera with 18-200mm...
How do i turn back on spy sweeper and my micro trend internet security
In order to disable the Anti-Virus components of Webroot Anti-Virus you must go to two separate sections:
Anti-Virus Shield Disabling
1. Click on the Options button on the left hand side of Webroot Anti-Virus
2. Go to the Shields tab of the Options Menu
3. Under the section labeled Anti-Virus Protection, take the checkmark out of the Protect against Viruses box.
Anti-Virus Sweep Disabling
2. On the Sweep tab, put the dot into Custom Sweep (please note you can only disable Anti-Virus Sweeps by using the Custom Sweep option)
3. Under the section labeled Sweep Settings Summary, click the Change Settings link which is next to Custom Sweep Settings
4. A Custom Sweep box will appear with various sections to click on. Click on the What To Sweep button on the left side of this Custom Sweep box.
5. On this screen, take the checkmark out of Sweep for Viruses under the Viruses section.
6. Click the OK button at the bottom of this screen and you will be returned to the Sweep tab. (Again please note that you can only disable Anti-Virus Sweeps by using the Custom Sweep Option which will now be selected)
Jan 22, 2010 | Microsoft Windows Vista Home Basic for PC
Prescott-533 can support sp-2
If your running windows with SP1 now without problems, there is no reason for SP2 or SP3 not to function correctly. Hint! When updating do not click the Express button in windows update. Click Custom. Try to download .Net framwork updates first. Continue using the custom button in windows update mainly for .Net framwork updates.
Happy holidays!
Mike
Dec 16, 2009 | Intel Motherboard
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Epson Stylus Pro 2200 printer help
I have the same problem with custom sizes. Also, some sizes are unavailable. I did get a custom size working by setting the margins to .25,.25,.25,.45,
Apr 13, 2008 | Office Equipment & Supplies
I don't know how to use custom eq
press the EQ button until it says custom on the seting then press the tuner select button left or right and it will say bass or treble use the volume to turn it up or down then u got the bass control.:)
Feb 14, 2008 | RCA RS2652 Shelf System
Setting Usier defined paper size
Hey osmund, You want to use your paper size which is 8.5 x 13" but in the custom paper size you are finding 8.4 x 14". Am I right. So, where is the problem my dear. Be sure, that your document size is in 8.5 x 13". Give Print command with custom size, it will print on that size you want.
Apr 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
