How do you change the tailight bulb in a Mercury Mountaineer? Mine is a 2004.
First open the rear hatch. Look just inside the door next to the rear lens assembly. There should be 2 screws that need to be removed. This should loosen up the assembly. Next gently pull the assembly back and out to you.Do not pull to hard or to far, you are still connected with wire. Next, squeeze the retainer and twist the bulb assembly ccw. You are there. Reverse it to put it back. Good luck.
