Question about Minolta EP1030/1030F CS/PRO Copier
Page not copied correctly
When copy is done it has a missed line down page that it will not copy on paper
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
Vertical or Horiz.?
try doing on glass instead of doc feeder, if ok then clean the small strip of glass( different then the big one)
if same problem is with drum or developper depending on which way.
Posted on Aug 26, 2008
Everytime I fax something on my HP Officejet 5610 all in one, the recipient receives the document with a line going down the left side of the page. How do I get rid of the line?
Lines on scanned and copied documents is usually caused by something on the scanner glass such as ink, correction fluid or trash. Open the top of the printer and clean the scanner glass surfaces with windex and paper towels. See this article for more details:
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Jun 26, 2012 | HP LaserJet 3050 All-In-One Printer
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
When I send a fax there is a white line down the center of the page. It does not do it when I make copies, How can I clean it or correct the problem.
Are you sure that there is no lines when you make copies?Because the scaner is used when you send faxes and when you copie, if sensor is bad or dirty lines would be wissible.
Clean it very well, with strong detergent, but in small amounts.Scratch the stains from corctour or similar...
Jun 14, 2010 | Canon FaxPhone L75 Plain Paper Laser
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Copying problem
Vertical lines on the copy usually indicate a dirty drum or Corona wire. The Corona wire should be cleaned each time you replace the toner cartridge. This is done by moving the Corona tab back and forth across the wire several times to clear it of debris. You may also want to check the drum for debris. Holding the copied page to where it feeds out and lining up the line or mark on the page will give you an idea as to where the dirt may be. Best of luck with your printing issue.
Greg
Nov 04, 2009 | Brother IntelliFAX 2800 Laser Fax
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
My Rocoh FT 4220 leaves a blank strip across every page that I try to copy. I have cleaned everything I could, but must have missed something. The blank strip is not always in the same location on the...
Clean the optical section(glass,mirrors,lems)Verify the paper dust on the edge of the cleaning blade,if the OPC drun scratched or the fusing hot roller scratched.Press the cleaning blade release lever down several times.Make a copy and stop the machine when the paper reaches the transport section.If the lines appear replace the OPC drum.After replacing the drum perform the Drun initial setting,Light Intensuty Adjusment,ADS voltage adjustment,Vsg adjustment.
Sep 25, 2009 | Ricoh FT3713 Copier
Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Aug 04, 2009 | HP Office Equipment & Supplies
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
26 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
